Question about Roper RAS8445KQ Top Load Washer
I have a RAS8445JQ0 W/M. My son opened up the machine and replaced the lid switch. However he was a bull in a china shop and I cannot get the cabinet back together. I do not see any clips or anything but some holes. I guess there are parts missing. What are they?
3 Suggested Answers
  • 686 Answers
SOURCE: I took apart my Roper top loading washer to
it's difficult to explain but be assured that they will only go in one way for them to function properly.
Posted on Apr 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 110.22852100 washer cabinet re-assembly
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Lid switch needs to be replaced
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 23, 2011 | Kenmore Washing Machines
I have a Whirlpool Gold Ultimate Care II washer (MOD# GSQ9669LW0) The washer stopped, was full of water and will not restart on any cycle or settings.
This problem sounds like a broken lid switch. Power to the drive motor is routed to the lid switch and if the lid switch fails, the machine will fail work on any cycle. Verify this by bypassing the lid switch.
Disconnect power to the washer then remove the screws securing the console to the rear of the cabinet.
Pull forward and up on the console and lay it back on the hinges.
Jump a wire between the outer terminals of the disconnected connector from the top of the cabinet then reconnect power. The problem is indeed the lid switch if the machine starts. Check the lid switch plunger and the lid switch attachment to the cabinet. It may not activate properly if the mounting is loose, re-tighten it. Replace the lid switch if the plunger is intact and and if it is mounted tightly and properly.
Jan 11, 2011 | Whirlpool Washing Machines
The washing machine (Kenmore 80 Series) runs but doesn';t drain at the end or spin. We think it's a lid switch perhaps? Where is it located though and do you possibly have maybe a diagram to look at? Thank...
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Replace the lid switch to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Jan 01, 2011 | Washing Machines
How do I remove the top of the washer to replace the lid switch on a 110 23832100?
Disconnect power then release the console from the top of the cabinet. Pull or pry off the end caps then remove the screw that secures the console to the cabinet top. Once the screws are removed, pull forward and up on the console and lay it back on the hinges.
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
major_appliances;subcat=washing_machines;brand=kenmore;product=kenmore_22422_top_load_washer;ptype=thread;make=kenmore;solution=1;channel=0197193999;sz=650x250%2c2x2;tile=3;ord=634994898287111? Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
Dec 30, 2010 | Kenmore Washing Machines
The washer filled up with water but wont turn on
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch. The machine, therefore, will not turn on when the lid switch is not working. Manually activate the lid switch and if still doesn't work, bypass the lid switch. Disconnect power then jump a wire between the outer terminals of the disconnected connector from the cabinet top then reconnect power. Replace the lid switch to address the problem if the machine works with the lid switch bypassed.
Nov 09, 2010 | Whirlpool LSN1000LW Top Load Washer
Our Kenmore washer (23812) stops working at the spin cycle, and the water will not drain out of the machine. Help!
Oct 28, 2010 | Kenmore 23812 Top Load Washer
Ras8445jq0 wont spin, agitates fine, replaced timer, lid switch is good tried manually jumping lid connector as well and no luck, motor isn't running or anything, but all other cycles work fine only sping...
You need to replace the direct drive coupling on the shaft of the motor. I have attached a breakdown for you. Number 13 in the picture. Not a costly repair.250
Nov 19, 2009 | Maytag Washing Machines
Model ras8445jq0 wont spin safty switch is good
how did you check the switch? Does it try to spin? Does it agitate?
Nov 08, 2009 | Maytag Washing Machines
I have a roper washer model#RAS8445JQ0 it washes but won't spin,could it be a relay or timer ?
most likely lid switch try pressing down with pencil if switch not completely broke.. if it works replace switch
Sep 06, 2008 | Roper Washing Machines
Kenmore 70 Series Washer
Most likely you need to replace the lid switch.
Open the lid and make sure the actuator that pushes the switch is still attached to the lid. Use a pen or screwdriver to depress the switch through the hole in the top of the cabinet, you should hear a click as the switch closes. I usually find that the switch has actually broken off from the cabinet and is hanging loose in the machine.
To replace the switch
Remove the screws that hold the console to the cabinet. Flip the console up and back like opening a car hood. unplug the wire connector for the lid switch. Pop out the two clips that hold the cabinet to the rear panel of the washer. The cabinet will tilt forward and slide off the machine base. You can now replace the switch from inside the cabinet.
If you need further help, please post the complete model number from the washer so I can see exactly how your washer is set up.
Mike
Apr 11, 2008 | Kenmore 22422 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
158 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
