Question about Toro Lawn Mower With Toro Power Tools
Toro lawn mower keeps stalling acts like starving for gas only 1 yr old
4 Suggested Answers
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
  • 17 Answers
SOURCE: Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Posted on Aug 11, 2009
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
The lawn mower won't stay running. It starts up without a problem. I mowed the lawn for about 45 mins and the mower sounded like it was out of gas. It has plenty of gas in it. If I tilt it, by...
Sounds like the automatic choke to me. When it acts up next time, remove the air filter, and observe the butterfly valve on the carb. Hold it open with a screwdriver, and see if it starts and runs. I have found that wireing the thing wide open solved my Toro problems. The mower is still under factory warrenty however, so you can always take it back! Hope this helps my friend!
Sep 09, 2011 | Toro Power Lawn Mower
Engine starts but immediately stops
Engine starts but stalls out. Plug cleaned and air filter removed.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start toro mower. cleaned spark plug , new air filter . will run for 2 or 3 seconds on prime , then stalls ,will fire every time , but won't continue to run what next? 22" self propelled...
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
755 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
