Question about Proform 680 LT Treadmill
Clicking sound coming from front base part of Proform 680, faster clicking sound when increase speed. Sounds like related to motor, not walking belt. Suggestions?
    Champion:
  • 218 Answers
Bad bearing in the front roller
Posted on Aug 12, 2010
2005 mercury 9.9 hp bigfoot motor
does it get faster with speed the clicking ? could be a bearing !
Apr 28, 2013 | Mercury Four-Stroke Outboard Motors, Model...
Proform ZT5 Treadmill clicking noise
Dear Sir:
If it sounds like metal rotating on metal then it could be roller bearings or motor bearings. Most of the time the bearings will have to be pressed out and the new ones pressed in. May be you must go the treadmill to workshop. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 05, 2012 | Proform ZT5 Treadmill
I have a 2000 jeep grand cherokee limited. When I start it there is a clicking sound in the front and whenever I push the gas the clicking goes faster. Let me knoe what you think the problem is.
clicking sounds that increase with motor speed can be a number of things, it can be a bad belt, water pump, or anything else run by a pulley , a stuck lifter, or even a bad cylinder. I'd need a little more info to help you,, Does it just tick, or is it a low thumping sound? slight ticking sounds can be a arching spark plug wire going to ground, those are easiest to locate when its dark and just looking at the motor while its running, you see the spark. If you could narrow the sound down a little, I could be of more help
Jul 13, 2011 | Jeep Cherokee Cars & Trucks
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
I need to calibrate the speed of my ProForm 680 LT.
Remove the front motor cover. Inside is a copy of the tech sheet. The procedure is outlined there.
These machines do not do an electronic calibration, it is a mechanical one. You must adjust the motor controller for max speed by following the procedure outlined.
If the speed readings are incorrect, you may be set for Kilometers rather than Miles. It's easy to determine. 3MPH=4.8KM...
Follow the procedure in your owners manual to change from metric to miles..
Dec 12, 2010 | Proform 680 LT Treadmill
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
I have a proform 650 treadmill. It is working ..but strange sound
The front bearings have failed and is causing the hammering noise will need to replace roller. Go to iconfitness.com go to customer service then replacement parts you will find your M# and pricing
Feb 25, 2010 | Nordic Track /proform Treadmill...
Clicking sound on Washer Spin Cycle
You are quite correct in thinking that it is the motor brushes that are worn.
You need to remove the motor and replace the brushes.
This will solve your problem.
Good luck.
Nov 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Proform 680 LT Treadmill Logo
366 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
