Question about FujiPlus FP-7688B 17" LCD Monitor
Monitor turns off and back on during use???
I have the fp-768 and looks great. The other day it started to turn off by its self is there an problem with over heat? All other functions work well. Can I change out a part??
  • 293 Answers
Hi...there, It's could be your backlight is burnt out... Go to my website, I got some parts you may use for your replacement. Thanks
Posted on May 08, 2008
It was the ac adaptor, easy $20 fix.
Posted on Apr 27, 2008
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Power button locked. How can I unlock??
May be Your Power Button damaged for usiging many days. you can open the casing and check the button link which connect to your monitor circuit. if any leckage or not connected with circuit then wash the button by thinner( not use other chemical like petrol). if not work in spite of do this then change your button.
Mar 06, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Compaq FP-5315 won't turn on goes to sleep every time
More likely to have bad caps with bulging top in the power supply, that is the first place to look for the monitor this old, see example of failed monitos due to bad caps:
Post back what you se sowe help you more.
Mar 04, 2010 | HP Compaq FP5315 15" LCD Monitor
I have a Compaq FP 5314 that flashes on and off at about every four seconds. It works on XP and shows everything up to the OS coming on. That is all the bios type info, but then starts flashing as above....
The problem is that UBUNTU is setting the screen-resolution to some values that your monitor does not support, e.g., 1920-by-1080, or not setting it to 60Hz.
During boot-up, your monitor uses 800-by-600, so it "initially" works, both with UBUNTU and XP.
Windows "detects" the monitor, and selects "usable" settings.
Attach a new monitor to UBUNTU, and then set the video-resolution to 1024-by-768 and to 60 Hz -- your Compaq should support those settings.
Dec 26, 2009 | HP Compaq FP5315 15" LCD Monitor
After unhooking Dell monitor, can't get it to work again.
You shouldnt have to hook both of them up.
turn off the computer and monitor unplug. the power cord to the power supply. leave the monitor hooked to the computer
remove the side panel on the left side of the computer.
look and find the wiring harness from the powersupply to the motherboard and remove it now press the power button on the computer for 1 minute this releasess any (esd) or Electronic Static Discharge. that may have built up over time.
wait for 3 minutes
during this time this will be a good time to blow out any dirt or debris that may be in the inside of the computere
now reinstall the wire harness back to the motherboard and connect everything back up and turn on the computer and then the monitor and see what happnes you should be ok after this ok?
let me know how this goes ok and please dont forget to rate the solutions that i have provided for you
best regards michael
Aug 06, 2009 | Dell UltraSharp 1905FP LCD Monitor
Monitor frequently changes into a series of black and white stripes.
The video board inside that connect this to you vid card is going bad and will need replacment. There is not really much you can do troubleshooting this. Thanks and good luck
May 24, 2009 | FujiPlus FP-568 / 15-Inch / 1024 x 768 /...
Images and letters are fuzzy on my Westinghouse Monitor
Your monitor settings are not correct or you have a bad monitor cable. Wide screen settings are sometimes hard to figure when you have a wide screen Westinghouse mntr. You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest?You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest? That monitor is a **** btw! take it back to Best Buy. No other store sells them that I know of.
Jan 15, 2009 | Computers & Internet
Dell latitude D610 and 1901 FP monitor
Did you hold down the Fn key and press the function key for the external VGA port? It should cycle as LCD only, LCD and VGA, VGA only and then back to LCD.
Dec 28, 2008 | Dell Latitude D610 Notebook
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Computers & Internet Logo
192 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
