Question about ViewSonic PJ506D DLP Projector
My projector is displaying text backwards - ViewSonic PJ506D DLP Projector
Unstable projector display
Ayo, Kumusta na ka kuya? Asa man mo i ate mayet karun? Emaili ko kuya asap....prestige_bands@me.com Gemma- tony
Jun 17, 2012 | Samsung Sp-m250s 3lcd Projector Hdtv Home...
Defective image: one color is reflecting in reverse (backwards) Can notice by reversed text
I would say that the lcd panel for that colour is now working in negative mode.
It happens and would require a replacement lcd panel, which is difficult to install and perfectly align without proper jigs.
better to wait till another dead EX30 comes up for sale cheap on ebay and get the whole optics block out of it and do a replacement.
Mar 22, 2011 | Epson EX30 LCD Projector
Projector is displaying everything backwards
I hope you have fixed it by now but just in case, go to menu and select the reverse option. It is set for rear projection at the moment.
Hope that helps.
Feb 16, 2011 | NEC VT595 LCD Projector
I have an Infocus LP350. The image it displays has lines running through it, which consists of the text displayed, but offset and a bit jumpy. There are also some dark black lines on the right. How can I...
if you reset the settings to factory default and the text is still like that, you have a colorwheel issue and probably a dmd chip problem. as for the dark lines, if they are more of a shadow on the edge, the colorwheel is collapsing. if they are thin and definite, you may have a main board or dmd chip problem.
Oct 23, 2009 | InFocus ScreenPlay 5700 Multimedia...
No way to get simultaneoulsy my videos on the laptop monitor and on tne projector PLC XU 73 card : ATI Radeon X700
Most laptops have a Function (Fn) key in an alternate color (blue maybe) from the usual key text color (white usually).
By pressing this key, along with another key that has text of the same (blue) color, perhaps labelled with "LCD/CRT" or a pic of a monitor, or of 2 squares - one single square and one double "square in square", you can toggle between the modes of:
1. Laptop display only,
2. external display only, or
3. Both displays.
Be sure to check your laptop model manual for specific details to make sure this is possible.
Jun 09, 2009 | Sanyo PLC-XU73 Multimedia Projector
Someone changed a setting
The setting is in the Menu. It sounds like you went to the "Image" section which lets you make the adjustments you list. Try the "Source" menu, then "Mirror". That's where you will find options for Rear Screen Projection, which makes the image backwards.
Feb 05, 2009 | BenQ MP610 Multimedia Projector
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Infocus projector, words projects backwards
change the orientation from rear to front in the menu
Dec 29, 2008 | InFocus In2102 Projector
ViewSonic PJ506D DLP Projector Logo
314 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
