Question about HP Office Equipment & Supplies
Ink system failure. will not print. gives error 0xc18a0306. Can I fix this problem myself?
  • Dimitar Todorov Aug 05, 2010
    What model is that? Do you use ink refills?
  • fullcircleva Aug 06, 2010
    drivers up to date. went to download drivers and rec'd message stated all my drivers are up to date and updated weekly. Would have been an easy fix though, and wish it had worked. Went and got an Epson Workforce 610. Still would like to fix HP though.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
Please down load the driver from the HP website and install the driver.
Posted on Aug 05, 2010
  • Bhagyanath N Aug 08, 2010
    Please remove the printer and remove all Epson driver from the add and remove program. Go to run and enter "devmgmt.msc" you will get device manager, Remove all of the Universal Serial Bus from the device manager and click on Scan for hardware changes. It will install all of the USB drivers. After that connect the all in on printer and install the software properly.
  • fullcircleva Aug 09, 2010
    bhagyanath, It is an HP Printsmart C6280. Since I couldn't fix it and I had to have a printer, I bought an Epson Workforce 610. So, what I need to do is take all drivers to both printers out of the device manager and reload the HP to see if it will work then if it doesn't , set up the Epson again? I still have time to return the Epson if I can fix the HP. Thanks for you help.
HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
Jan 06, 2015 | HP Photosmart D7360 Digital Photo Inkjet...
Ink system failure
A Google search found this possible solution for you at HP:
Ink System Failure C6180 error 0xc18a0306
Jul 25, 2014 | HP Photosmart C6180 All-in-One Printer,...
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0306. Ink System Failure?
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0105. Ink System Failure?
May 04, 2011 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart C5180 Ink System has Failed Error:0xc18a0306 Can't clear this error
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
get more information for HP printer errors . Hope this helps you.
Good Luck!
Aug 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C7280
Hi there It worth a try nothing to lose and it may work. Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 02, 2010 | HP Photosmart C7280 Laser Printer
Error message says: ink system has failed. Unable to print. refer to printer documentation. Error: 0xc18a0306. Turn power off then on again.
Hi
Please see this link to solve your issue--
HP Printer ink system Failure
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | HP Photosmart C6280 Printer
Ink system failure
All Asserts beginning with "0xC18A"
Replace Unit: unit can not be recovered or is almost certain to fail again.
It is a issue if your unit is in warranty HP Will relce it free of cost for you or you can check for any upgrade options with HP 1800 474 6836
Good Luck
Aug 29, 2008 | HP Photosmart 3310 Printer
208 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
