Question about Brother GX-6750 Typewriter
I put in a new cartridge and it still will not print. It doesn't move as it should. Just stays in one place.
    Sergeant:
  • 329 Answers
Check small star drive (black part ) that moves as you type this parts turns the ribbon. This is a adjustment or it has parts broken...
Posted on Jun 12, 2008
Printer
The steps below should help you override the error and make the printer accept the cartridges and allow you to print.
Instructions
    • 1
      Remove and replace the print cartridge. If that doesn't solve the error, move on to Step 2.
    • 2
      Remove the print cartridge from the machine.
      • 3
        Wet the end of a cotton swab with rubbing alcohol.
      • 4
        Wipe the copper colored contacts on the print cartridge with the cotton swab to clean.
      • 5
        Wipe the contacts in the printer where the cartridge sits.
      • 6
        Replace the cartridge and try a test print. If removing residue for a clean connection didn't solve the error, move on to step 7.
      • 7
        Turn off the printer.
      • 8
        Unplug the printer from the power source and leave it unplugged for 15 to 30 minutes. This will reset the printer.
      • 9
        Plug the printer back into the power source and turn it on.
      • 10
        Print a test page.
    Regards,
    Suhail
    May 20, 2012 | Lexmark X1240 All-In-One InkJet Printer
    I have epson DX7450 tells me ink out replaced all but still ink out report have don eall the books operation guide please help regards B D
    Check whether cartridges is placed properly ?
    Unplug the unit for 30 minutes and plug back the power chord to the unit .
    Nov 01, 2008 | Epson Office Equipment & Supplies
    When fax comes through paper is blank. I've tried 2 different cartridges
    Replace the print cartridge
    When you notice that the print becomes light or ink low or when install new ink
    cartridge appears in the display, replace the print cartridge. The part number for
    replacement cartridges is HP 701.
    1. Take out a cartridge from its packaging and carefully remove the tape covering the
    printhead.
    Hold the cartridge by the colored top or black areas only. Do not touch the copper
    area.
    2. Press the Access Cartridge button on the control panel.
    The cartridge carrier moves to the install position.
    1 Access Cartridge
    CARE AND
    MAINTENANCE
    CARE AND
    MAINTENANCE
    CARE AND
    MAINTENANCE
    CARE AND
    MAINTENANCE
    CARE AND
    MAINTENANCE
    CARE AND
    MAINTENANCE
    CARE AND
    MAINTENANCE
    Care and maintenance 45
    3. Open the control panel and cartridge compartment cover (it will click and remain
    open).
    4. Push the cartridge down and remove it.
    5. To load the cartridge insert the cartridge as shown below. When the cartridge is
    pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
    into place.
    If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
    step.
    1 Control panel
    2 Cartridge compartment
    cover
    46 Care and maintenance
    Clear jammed documents and paper
    6. Close the cartridge compartment cover and control panel.
    7. Press Start/Enter.
    8. Press 1 for new cartridge, or 2 for the old one.
    • When you put in a new cartridge, you must choose 1:New
    • When you put in a used cartridge, choose 2:Used. This helps you to check the
    correct amount of ink you have left.
    TIP: If you mix up several used cartridges, it is not possible to check the correct amount
    of remaining ink. Once you have put in a new cartridge, use it until it is completely
    exhausted.
    Nov 11, 2011 | HP 640 Inkjet Fax Machine
    Will not print. Moved computer from one room to another. Was printing fine before moving. Says that the ink cartridge is in the wrong place. Almost new cartridges. I have removed them replaced them....
    Try to wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from dirt and possible clogs. If that doesn't help, try to insert a different known working cartridge to determine if the other is faulty.
    Jun 20, 2011 | Lexmark All-in-One Printer with PictBridge
    How to change ink cartridges on an Epson CX 3800
    Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
    1. Make sure the Epson CX printer is on.
    2 Make sure the document cover is closed, then open the scanner
    Caution: Do Not open the scanner when the document cover cover is open.
    3. Press and release the " ink " button. The ink cartridge moves to the check position and the
    " On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
    cartridge to the _ink out mark.
    Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
    Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
    button to move it.
    4. Press the " ink " button again
    a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
    b. If all of the empty or low cartridges have been identified, the print head moves to the ink
    cartridge replacement position.
    5. Open the cartridge cover.
    6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
    7. Before you open the new ink cartridge package shake it four or five times, then remove it
    from the package.
    Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
    Do Not touch the green chip on the front of the cartridge, this can damage the
    ink cartridge.
    8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
    place.
    a. Replace any other cartridges that need to be replaced.
    9. Close the ink cartridge cover and press it until it clicks into place.
    10.Close the scanner.
    11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
    takes about one minute. When it's finished the " On " light stops flashing and remains on.
    and the " ink " light goes out.
    Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
    Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
    Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
    Feb 09, 2011 | Epson Office Equipment & Supplies
    HOW DO I CHNGE THE CARTIDGE.?
    When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
    1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
    Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
    3. Open the control panel and cartridge compartment cover (it will click and remain open).
    4. Pull the cartridge toward you and remove it.
    3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
    If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
    5. Close the cartridge compartment cover and control panel.
    6. Press Start/Enter.
    7. Press 1 for new cartridge, or 2 for the old one.
    • When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
    TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
    Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
    How do you open for ink replacement?
    Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
    1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
    2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
    3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
    Installing a new print cartridge Follow the steps below to install a print cartridge.
    1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
    2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
    3. Close the cartridge compartment cover and control panel.
    4. Press the Start/Enter button.
    5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
    for more information follow the link:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
    Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
    How do I put new cartridge in
    Follow this procedure to install print cartridges in you printer.
    1 Turn on the HP Officejet, and then lift open the print-carriage access door.
    The print carriage moves into view.
    2 After the carriage stops moving, push down on the top of the print
    cartridge to release it, and then pull it toward you out of its slot.
    3 Remove the new print cartridge from its packaging and, being careful to
    touch only the black plastic, gently remove the tape by using the pink pull tab.
    Caution! Do not touch the gold-colored contacts or ink nozzles.
    Once you have removed the plastic tape, install the print cartridge
    immediately to prevent the ink from drying in the nozzles.
    4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
    Press firmly until the print cartridge snaps into place.
    Caution! Do not attempt to push the cartridge straight into the slot.
    It must slide in at a upward slight angle.
    5 Hold the tri-color print cartridge with the HP label on top. Slide the print
    cartridge at a slight angle into the left side of the print carriage.
    It must slide in at a slight upward angle.
    Note: You must install both print cartridges in order for your HP Officejet to work.
    6 Close the print-carriage access door.
    “Press OK to print Align page” appears on the display.
    7 Press OK.
    Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
    Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
    I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
    You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
    The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
    Here's the relevant link:
    Cleaning the Print Cartridge
    Good luck and post back your results.
    Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Changing the ink cartridge in Epson Stylus CX4200
    1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
    2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
    3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
    4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
    5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
    6. Before you remove the new cartridge from its package, shake it four or five times.
    7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
    8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
    9. Carefully lower the scanner, until it clicks into place
    10. Press and release the INK button.
    The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
    Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
    May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
    Brother GX-6750 Typewriter Logo
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
