Question about Cell Phones
The screen on my LG Chocolate Touch, is not working at all,, what should i do
  • 713 Answers
It can be deduced from your problem that there is no longer a contact between the inner touch pad and the outer touch screen,hence the touch is no longer responding.
The solution is to take apart the phone and replace the touch screen,
Here is a detailed disassmbly to assist you in replacing the touch screen;
1.Remove your battery, sim and memory card. Six screws need to be removed. Two at the top of the phone are covered by plastic stickers which will peel off.
2.Run something like a credit card around the join of the battery compartment to release it from the rest of the phone.
3. Two ribbon connectors need to be disconnected. Each one attaches like a plug and socket. Just lever them up to unplug. You'll then be able to lift the two green circuit boards away from the rest of the phone.
4. Remove the six screws you can see and then you can remove the next layer of the phone.
5.Run your plastic tool along the join of the front cover in order to release it.
6.Two ribbon connectors need to be disconnected. Again, each one attaches like a plug and socket. Just lever them up to unplug.
7.Lever the camera out with your plastic tool. It is stuck down lightly with double sided tape and should come away easily.
8.Lift the screen away from the front cover. It should be loose. Next peel away the big black piece of sticky tape. Now slide your plastic tool under the LCD screen to separate it from the green circuit board. It will be stuck down with double sided tape. Once the double sided tape has been released, pull the screen in the upward direction.
9.You should now have the small LCD screen removed.
Thanks and take care
Posted on Aug 05, 2010
Lg chocolate touch screen not working
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when the call comes the answer button which used to display as green gets greyed out and does not lets you answer the call. I have tried upgrading the software as well as a factory reset bit it has not helped. C
Can somebody advise how/if it can be fixed?
Aug 28, 2010 | LG Chocolate 3 Cell Phone
My l.g. Chocolate touch screen is not working right....i can't touch it or if i do it goes to something else
mine is doing the exact same thing.. i have no idea how to fix it either. let me know if you figure something out!
May 20, 2010 | Cell Phones
My lg vx110000 touch screen stopped working after i sprayed windex on a cloth and cleaned the touch screen.
i did this twice with my chocolate touch and mine also stopped working /: the prollem is you had a scratch in your phone, or it got into one of the cracks, and jacked things up in there.i wouldnt do that anymore :|
Apr 11, 2010 | LG enV Touch VX11000 Cell Phone
LG chocolate touch screen goes black once I call
I had the same, or a very similar problem. What happened with mine, was the sensor on the upper right corner of the phone was getting blocked. It is supposed to sense when you have the phone next to your face and then it will darken the screen, Mine had plastic that was obstructing it. Hope this helps.
Apr 06, 2010 | LG CHOCOLATE VX8500 Cellular Phone
LG chocolate touch screen cracked
Hi arielautumn,
The only solution is get the entire screen repaired,,, then only the screen view will be clear,,,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
Mar 06, 2010 | LG Cell Phones
Unlock lg chocolate touch cellphone to be used with other carrier
You can unlock LG BL20 chocolate at http://www.fastgsm.com/en/lg/lg/bl20-chocolate/unlock-code-usim-locked
Jan 24, 2010 | Samsung Star GT-S5233 Cell Phone
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Hey i have a question about my chocolate phone
Your phone needs to be replaced. The touch pad simply just went out on you.
Nov 28, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
717 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
