Question about Neovo F-417 17" LCD Monitor
Neova monitor green light flashes then message no signal
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Monitor power light flashes yellow/green
the monitor power light turns green and then switches back to yellow but there is no signal.
Nov 28, 2009 | Acer AL1917W LCD Monitor
My computer power light flashes on and off but no picture on the screen, the light flashes like the screen is off with brief green light flash in between. I want to know if that is just a problem with the...
Try unplugging te signal cable from the PC and see if it changes in any way, EG. you get a no signal message or anything also try the menu button again. If you get anything on the screen then there is a mismatch between the PC and the monitor, Screen Resolution, Bent pin in the cable or something similar.
Sep 15, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Jun 07, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Cornea 15" monitor
If possible, try a new video cable. If it does not correct itself with a new cable, the problem is not serviceable. Flat screens do one of three things: inverter will go out (no light), line input board signal failure and power supply low volts on 12v B+.
Mar 28, 2007 | Cornea CT 1503 (Black, White) 15 in. Flat...
Philips 170C Monitor
i believe your monitor signal cable is bad or twisted.try straightening the data cable that connects to your cpu, if it doesn't work, replace the signal cable.
Feb 26, 2007 | Philips 170C4FS 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
71 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
