When i burn a dvd in my hp dv6000, it does burn till d end, stops at " 0 seconds remaining" and the laptop hangs then..so even though data is there on dvd,, it shows 0 bytes..n d dvd becomes useless...solutions plz...
  • 212 Answers
Ur dvd lens maybe need to clean.if u r sure from its safety & if u can open it,just clean the lens
Posted on Aug 11, 2010
I have two intel based hp dv6000 laptops. Both are having problems. I suspect the mainboard because everything else was replaced the last months. laptop 1: Not booting, no screen (nothing!!), no beeps,...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly:
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge:
hope this helps you
Sep 18, 2011 | HP Pavilion dv6000 Motherboard
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
When i start it doesn't start sometimes. sometimes it starts but after a few secs a noise comes and system switches off
There's a similar problem with the DV6000 that is caused by the built in graphics card overheating and telling the computer bios to turn it off and stop it overheating the whole motherboard. unfortunately once this has happened the system can stop the laptop booting even from cold. I've temporarily fixed a couple of them by removing the CMOS battery for 24 hours and puttin a shim between the graphics card and the heat sink. In the end you're probably need a new motherboard though
Jan 16, 2011 | HP Pavilion dv1000 Notebook
I have DVD RAM (Super Multi Secure disc drive) from LG . It starts burning and stops suddenly with a 'speed breaking' sound at 0% itself.May it start burning and end at different progress like 10% 20% with...
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty ?
good luck
Aug 30, 2010 | LG Computers & Internet
How can I tell if my HP Pavillion dv6000 can burn DVDs? I tried to with DVD Flick but the dvd came out blank after 3 hours of supposed burning.
Try creating a normal CD-R for example just a picture using windows transfer which is simply double clicking your CD drive icon in my computer dragging a picture on to it then burn the files should be on the left, if so then your burner should be fine. I Would suggest using NERO to burn DVD's
G
Feb 19, 2010 | Computers & Internet
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have an hp pavilion dv6000 and the disk drive doesn't work
i had the same exact problem with my dv 6000 notebook. The dvd Rom is damaged. U will have to get a new one. I tried lots of software but didnt work. i also wasted many cd'c nd dvd's which it didnt burn and also made them unusable.
So get ur dvd Rom replaced as sson as possible and another tip for future is that these dvd roms give up after writing about 100 dvds max i along with my 3 frnds having dv 6000 laptops have exprienced this. My frnd has now got his dvd rom replaced for the 15th time within 1 and ha;f year.. so replace ur drive.
Aug 10, 2009 | Computers & Internet
HP DV6000 Battery problem
Bring it back to the repair shop if it has still repair warranty. They should take care of it.
Dec 04, 2008 | HP Pavilion dv6000z Notebook
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
