Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have a 12,000 gallon abg pool Also the water is from a well system The low salt warning light came on I then cleaned the cell and reinstalled the cell only to have the High salt light come on I then checked the salt ppm with is at about 7800PPM I then unplugged the cell and replugged the cell and it worked for one day again giving me the low salt green warning i then cleaned the cell again only to get the high salt alarm again AT what PPM would the salt cell stop working
  • 297 Answers
Any thing over 3500 can create alarms.
First of all make sure you are useing a test kit for salt that reads in #'s not color
your system can read low salt when it is high or even high can read low
The system only really knows something is wrong
your 7800ppm is ridiculously high
Now start draining 20% of your water at a time and refilling giving the system at least 6 hours of just filtering between drainings until you get to as close to 3000ppm as possible
under 2700ppm and you will not produce enough chlorine and can trigger alarms any higher than 3500ppm and you can trigger alarms,go cloudy, and not to mention corode any metal parts like an aluminum ladder
once you get the ppm to 3000 clean your cell one last time and you should be good to go
I would also check your water for metals since you used well water.
you may need to get a metal reducer to add to the pool
Posted on Aug 05, 2010
Pump goes into sleep mode because of low salt light. I have added 240 pounds of salt since the light came on and fell that I may be haveing other problems. Would it be normal to have to add that much salt...
No more salt for now!!!!! 1st thing you need to do is check your salt ppm.. must be around 3000ppm.. The 8110 models have issues with their cells that will continue to give you a low salt reading regardless of the salt level.. You must check the cell for calcium build up and clean.. You can soak with vinegar or as others recommend, muriatic acid to clean the cells. Pressure flush to get all the "White Flaky" stuff out.. Dirty cells WILL give you a low salt error on the unit.. If after cleaning the cells you still get this code, you may have a bad cell.. If you are just starting out and the unit is new, YES you will probably add over 300 lbs of salt to get you going and be around 3000ppm on a 14000 gallon pool... Be sure to run your pump only for 24 hrs to properly dissolve the salt and then set your cycle...
Hope this helps...
Sep 08, 2011 | Intex Automatic Salt Water System for ...
This is the second summer for my krystal clear salt water system (above ground intex pool). When the low salt light came on I cleaned the cell as directed but the light came back on. I shut it down and...
Did you check the salt level and was it between 2000 to 3000ppm?? These are the two causes for the low salt alarm.. Dirty scale buildup on the cell and low salt level.. Also, you may need to add a scale buildup preventer. hth makes a bottle called "cell saver" it works okay and prolongs my cell cleaning cycles...
Aug 10, 2011 | Intex Automatic Salt Water System for ...
Once a week I've been adding salt (80 lbs) to my pool and again get low salt code (91)....it has been very unusually hot (HTX 110) is this causing the problem and I need to add more?
1st... Check your salt level consentration.. If okay... 2nd, Check you electrolytic cell, may be plugged with white flaky calcium stuff. The white calcium build-up on the cells will cause a low salt alam.
Jul 21, 2011 | Intex Automatic Salt Water System for ...
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
How to stop it frfom beeping/flashing 91 low salt.
1st... Check electrolytic cell and clean with vinegar...If white scalley stuff inside, cap one end and soak for 6 to 12 hrs and rinse until clean
2nd...check salt level, see manual for PPM, if low, add salt.. If you have a big pool 12000 to 15000 gallons, you will have to add up to 100 lbs of salt..
3rd... Run only pump for 24 hrs to dissolve salt..
4th... Set you cycle and should be fine
Hope this helps and rate if it does
Jul 16, 2011 | Intex Automatic Salt Water System for ...
Have put 280 lbs of salt in my 9300 gaoole pool and still getting the low salt light. What is the next step? Just set up the pool last week but the chlorine converter is from late last year. It did not...
By my calculations you are about 50 lbs over the requirement. Which code are you getting? I'm guessing code 91. Have you removed and cleaned the electrolytic cell from the chlorinator? I get lots of calcium on mine from hard water from the well requiring a cleaning at least once per week. If you get this working and get a warning that you now have too much salt you'll need to drain off water and re-add to get the salt content correct.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
240 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
