Question about Neff Microwave Ovens
Neff ovens does it need to be hard wired or via a 13 amp plug
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
You dont say what model if microwave most models is 13a supply if single built in oven 13a also ok double oven needs 30a supply/ hope this helps
Posted on Aug 05, 2010
I have a neff B6774N0GB combi oven. Activated the hot air button and it has tripped the circuit breaker. Fan element examined and looks perfect. Oven is isolated from other appliances
The hot air function uses a great deal more current than the other functions. Check the tag on the oven for current requirements, and check the rating of the circuit breaker in use. If the breaker is rated lower than the ovens rated maximum current draw, it will trip under the load. If the rating of the breaker is above the ovens maximum current draw, and there is nothing else plugged into that circuit, the breaker may need replacement.
Sep 14, 2016 | Neff Microwave Ovens
Where is the light bulb housing in a Neff oven/microwave, please?
Usually accessible from the outside of the case via a small door with a single screw.
Jan 21, 2016 | Neff Microwave Ovens
Hi Guys Neff oven/microwave coming up with an
make this: God bless you
A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
Nov 02, 2013 | Microwave Ovens
Hi getting an error 4 on a Neff oven/microwave. any ideas out there
make this and fix it. God bless you
Nov 02, 2013 | Neff H7871 Convection/Microwave Oven
What size fuses for the plug does the hitachi mcb30 microwave take? 2 13 amp fuses have now blown?please advise?
It should normally use 13 amp fuses. The blowing of the fuses could be caused by a short somewhere either in the plug top or somewhere else along the circuit.
Dec 30, 2010 | Microwave Ovens
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
How to repair venting fan in neff micro/oven
what is the fault precisely?is the fan not working?If so, you have to remove the fan carefully after opening the panels & removing its thimble connectors & replace it, Voila!
Jan 03, 2010 | Neff B7740N0GB Microwave Oven
I have a Neff Microwave/Oven/Grill combo. The grill and the oven parts still work, but the clock has gone off and the microwave part does not work. What can i do to fix this?? Thanks
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jun 25, 2008 | Neff Microwave Ovens
Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Neff B7740N0GB Microwave Oven
Neff Microwave
check control circuit and full wiring and connectors.
Dec 01, 2007 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
224 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
