Question about Maclaren Volo - Silver Frame - Coffee Stripe Umbrella Stroller
Can't unbuckle Volo - Maclaren Volo - Silver Frame - Coffee Stripe Umbrella Stroller
How to clean maclaren volo stroller?
Hi
We would recommend you contact Maclaren for assistance
Sites maclaren US Site
Jun 29, 2014 | Maclaren Volo - Carbon Black Umbrella...
Saab 900s seatbelt will not unbuckle
spray wd40 in the latch to free the lock
Mar 26, 2012 | Saab Vehicle Parts & Accessories
I need a replacement hood for my maclaren volo stroller
Unless you are able to find someone with it on craigslist or some other trading site, it does not look like that item has the hoods sold separately.
Jun 10, 2011 | Maclaren Volo Umbrella Stroller
I want to get a buggy hood for a maclaren volo in black
Hi.
The best way to get parts for the Maclaren is contacting factory.
Please open the page below, select your region and country, and use the Customer Service> Contact link at the bottom of the page to contact Maclaren.
Here the web site.
Regards.
Ginko.
Aug 15, 2010 | Maclaren Volo - Black Umbrella Stroller
Seat belt buzzer , how do you turn it off.
Hope this helps ya.. Cobra.. :-)
Belt-Minder® Deactivating/Activating Vehicles Built After 5/27/03
Preparation
  1. Before deactivating/activating the belt minder, set the parking brake.
  1. Place the transmission range selector lever in PARK.
  1. Place the ignition switch in the OFF position.
  1. Close all the vehicle doors.
  1. Unbuckle the driver and passenger safety belts.
  1. Turn the ignition switch to the RUN position. (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 minute).
  1. NOTE: Step 3 must be completed within 50 seconds after the safety belt warning lamp turns off or the procedure must be repeated.
    For the seating position being disabled, buckle then unbuckle the safety belt 9 times, ending with the safety belt unbuckled.
  1. NOTE: After Step 3, the restraint system warning indicator lamp turns on for 3 seconds.
    Within 10 seconds of the safety belt warning indicator turning on, buckle then unbuckle the safety belt.
  1. The beltminder activation or deactivation is confirmed by the following sequences:
    • If the beltminder is enabled, this procedure will disable the beltminder for that specific seating position. The safety belt warning indicator lamp will flash 4 times per second for 3 seconds to confirm that the deactivation procedure was successful.
    • If the beltminder is disabled, this procedure will enable the beltminder for the specific seating postion. The safety belt warning indicator lamp will flash 4 times per second for 3 seconds followed by a second series of 4 flashes per second for 3 seconds to confirm that the activation procedure was successful.
  1. After confirmation, the deactivation/activation procedure is complete.
Vehicles Built Prior To 5/27/03
Preparation
  1. Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).
  1. Unbuckle the driver safety belt.
  1. Place the parklamps/headlamps switch in the OFF position. (if vehicle is equipped with Autolamps, this will not affect the procedure.)
  1. Turn the ignition switch to the RUN position (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 to 2 minutes).
  1. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
    Buckle then unbuckle the safety belt 3 times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
  1. Turn the parklamps/headlamps on then off.
  1. Buckle then unbuckle the safety belt 3 times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for 3 seconds.
  1. Within 7 seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled and disable the belt minder if enabled.
  1. The following sequence of events confirm the belt mnider is enabled:
    • flashing of the safety belt warning belt lamp 4 times per second for 3 seconds
    • 3 seconds with the safety belt lamp off
    • flashing the safety belt lamp 4 times per second for 3 seconds again
  1. The safety belt lamp flashing 4 times per second for 3 seconds provides confirmation of belt minder disabled.
Jun 15, 2010 | 2004 Ford F150
Audible seatbelt warning keeps on sounding on my 2005 f150 ford truck
From the F-150 Forums, since I just bought one and this worked!
This is straight from my 2009 f150 owners guide
Preperation
1. the parking brake is set
2. truck in park
3. ignition switch is in off position
4. both seat belts are unbuckled
Disable Belt-Minder
1. turn the ignition switch to the on position, DO NOT START THE ENGINE.
2. wait until the safety belt warning light turns off. (approximately 1 minute).
* step 3 must be completed within 50 secs after the safety belt warning light turns off.
3. buckle then unbuckle the seat belt nine times, ending in the seat belt unbuckled.
* after step 3 the restraint warning light, (airbag light) will turn on for three (3) seconds.
4. within approximately seven (7) seconds of the light turning off, buckle then unbuckle the safety belt.
* the restraint system warning light will flash four, (4) times per second for 3 seconds for confirmation
you can do this for the passenger side also!!!
*NOTE
in step 3. after three times buckling and unbuckling the restraint warning light lit up in my truck. SO I WENT TO THE NEXT STEP, (STEP 4). waited 3 seconds and i buckled and unbuckled.
in the buckle /unbuckle procedure do it some what slowly and watch for the light. it may not take 9 times.
__________________
May 08, 2009 | 2005 Ford F-150
Hood for my maclaren volo
you can order one for $35 from here:
http://www.maclarenbaby.com/us/content/view/164/88888914/lang,en/
Mar 17, 2009 | Maclaren Twin Techno Storm Umbrella...
Adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
Mar 15, 2009 | Maclaren Volo Umbrella Stroller
Seat Belt Chime
Belt Minder Deactivating/Activating
Preparation
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete. user_offline.gif
Apr 02, 2008 | Car Audio & Video
I have just installed a Kenwood MP3 player with USB reciever. As soon as I wired it up, I blew the Audio fuse and had to replace the 10amp fuse. However, the system is not powering up still. Am I missing...
Creo que cometiste un error por ahi en la conexion ya que por lo que dices parece que se volo el amplificador de audio del estereo por eso volo el fusible .
Mar 31, 2008 | Audio Players & Recorders
Maclaren Volo - Silver Frame - Coffee Stripe Umbrella Stroller Logo
52 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Jim Goldsmith
Jim Goldsmith
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
