Question about Cross Watches
The hands are not moving. Do you manually wind cross watches? Does it work from a battery?
  • 2,334 Answers
Push the crown in, flush with case and turn it anti-clock wise. If you do not hear any clicking sound whilst doing that - your watch is battery driven. If you hear clicking sound - your watch is spring driven (mechanical).
Rate me, please.
Posted on Aug 05, 2010
Have new battery lite works and digital working i tunn hands like to wind it and they move
The hands are sliding at the base. set at 3:00 and a drop of crazy glue should move them when set.
good luck
Apr 22, 2017 | Watches
Mk 5473 watch is loosing time
Okay, so I'd the watch dial says automatic or manual wind you should be able to wind the watch to get it to start working. If the second hand is sweeping buy the minute and hour or just minute hand does not go around properly there are different issues. One. It could be the pinion that is loose, (major repair) two, the watch needs an overhaul meaning cleaned and re oiled(less likely). If only minute hand is giving trouble, its loose(the 2nd hand) or the pinion is loose.
Mar 26, 2013 | Michael Kors MK5473 Ladies Logo Watch
Watch stopped working
Try winding it by hand. If it will wind manually and works then the problem is the 'winding mechanism' If it won't wind by hand then you need a watchmaker. Find one that is certified if possible, they are the most schooled.
Oct 08, 2012 | Fossil Ansel - ME3022 Analog Watches : One...
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Second hand stops for a few seconds and then starts again over and over again
Try manually winding it (assuming it's not a quartz watch). If a mechanical watch is not worn daily it will run down and need to be manually wound to get going. Turn the crown clockwise about 40 turns.
Apr 25, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
My watch no longer functions even after winding.
I have found that some of these "automatic" Fossils also contain a battery. That is how that provide an automatic watch at such a cheap price. I recommend taking it to a jeweler to have them check this. If it needs repair it will likely cost near the watche's replacement value.
Oct 16, 2009 | Fossil Batman Rotor Style Automatic...
I can't get my head around how to manually wind my Fossil ME1020
You are not supposed to wind the watch, in simply winds itself with the motion of your wrist. A weighted wheel located in the back of the watch winds a spring that powers the second hand. The minute and hour is power by quartz and a battery.
Apr 05, 2009 | Fossil ME1020 watch
Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
May 02, 2008 | Rolex Daytona 116520 Wrist Watch
Watches Logo
140 people viewed this question
Top Cross Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Cross Watch Expert? Answer questions, earn points and help others
