I have a Canon MF6540 that has quit working. The error on it says download connected and none of the buttons work including the on/off switch. I've been reading about the system support tool but I don't know where to find it. Actually I'm not sure what it is. Can you help me with this issue? Thank You!
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
leroyal
  • 2120 Answers
SOURCE: fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Posted on Dec 29, 2008
halbrook
  • 560 Answers
SOURCE: lost cd for canon pixma mp160 inst. help. quite urgent.
download vista driver here.
scroll to the bottom of page and check "I agree...." then click download link.
Posted on Nov 06, 2009
canontech
  • 1219 Answers
SOURCE: I have a Canon Image MF6540: standby download has
That means that you have software issues. You need to upload new system, language,... over service support tool - call service
Posted on Jun 15, 2010
SOURCE: I HAVE A CANON IMAGECLASS MF6540. DISPLAY STATES
Your printer has a bad IP Board. If it is still under warranty you will have to take it in to an authorized Canon dealer and have them replace the board. Other people have given the solution that it just needs flashed because the boot information is corrupt or missing. This is the case but there it no firmware to download to correct the problem. The board has to be replaced. The repair for this can range in price but the dealership around me wanted $660.
Posted on Nov 11, 2010
How do i get canon imageclass mf 6540 to scan
Such printers with scanners built into them are know as Multi Function Printers. It is possible you have downloaded a 'printer only' or generic printer driver software.
Here are the links to the 3 bits of software you require:
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100242106EN.htm
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200155901EN.htm
3 (only for 64 bit windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114601EN.htm
3 (only 32 bit Windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114501EN.htm
May 05, 2014 | Canon ImageClass MF6540 Copier
Service manual mf6540 canon
hello friend, you can find the canon mf6540 service manual in below link:
Canon imageClass mf6540 service manual:
http://goo.gl/kW6ZF5
thanks
Apr 22, 2012 | Canon ImageClass MF6540 Copier
Service error 5200 Keep getting this message Have
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Canon ImageClass MF6540- works fine for printing, but scanning complains connection problem on Dell Dimension E521. However my other Dell Dim 9200 computer runs fine for both printing and scanning. What...
Need some clarification about the error.
We need to know the exact error.
Generally all the scannars use TWAIN technology which bridges the scanner with WIA(windows imaging aquisition).
We need to know if WIA which is a part of the operating system is working. For diagonasting we can try using teh scanners and camera wizard from control panel or we can use mspaint even.
If WIA is working in that case the problem may be with the registry values of the scanner.
WE can try making a new user account with admin rights and then we can try installing the scanner. We can even try using Revo uninstaller for uninstallation of the scanner because it will remove all the entries from registry, then we can try scanning.
BEST OF LUCK.
Feb 11, 2010 | Canon ImageClass MF6540 Copier
Canon ImageClass MF6540 scans but has error light
use your computer go to command promt and do ping to copier machine ip add, see there is any reply .If there is reply ,your machine is connected to your p.c.then use the printer driver do a test print.
Aug 19, 2009 | Canon ImageClass MF6540 Copier
HAVE A DOS BAKERY PROGRAM THAT IS USED DAILY. OUR XEROX PRINTER BIT THE DUST AND MY BOSS HAD ME RESEARCH AND PURCHASE A NEW ONE. PURCHASED A CANON MF6540. ONLY PROBLEM IS, NO ONE TOLD ME IT HAD TO BE A DOS...
There is a workaround that will work for many dos based programs.
It will remove several of the advanced feature from your printers functionality but may solve the problem.
Try this:
Open control panel, switch to classic view if not already in it. Open the Printers folder, then Right-Click on the Canon MF6540, select properties.
Once it opens the instruction may vary slightly for your printer but should roughly be:
1. Select the advanced tab, then click print processor, then select one of the RAW modes on the right and Ok twice to close the windows.
2. Try printing in the DOS program, if it fails, repeat step one and try the next option. If none of the RAW modes work, try the TEXT mode.
If none of these methods work you may need to emulate a LPT Port for the DOS program to Print to, forward it to the Printer and then repeat the above process. DOS programs are notoriously finicky about settings so you will likely have to try several settings to find one that matches.
If your first attempts fail and you need to emulate the LPT port get back to me by adding a comment to this post and I will see if I can find a good emulator to try for you. Or you can buy a router to connect the printer to that already has emulated LPT software such as the Linksys WRT610N. Sharing the printer through such a router creates a virual LPT port on your computer which may work.
If you need more direct help, try clicking my name and clicking Ask Me for paid support. If you can handle the normal speed here in the forums simply reply and we will help you as soon as we're able.
Hope this helps FixYa,
Chris
May 14, 2009 | Canon Office Equipment & Supplies
103 people viewed this question
k24674
jasbo
jasbo
