Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
The pool pump does no start running make a noise and I have to turn off the breaker and wait a few minutes and after that I turn on the breaker and then start running I think is the capacitor.
  • 30 Answers
Could be the centrifugal switch inside the motor is sticking, not allowing the start windings to be energized
Posted on Aug 26, 2010
Pump not working, just clicking noise when power turned on and button pressed on the control panel. ? previously tripped out, but lights all working ok, What should we do?
i am going to assume its a VS pump. turn off the main breaker for 5 minutes to allow the system to reset. turn off the breaker to pump as well. after reset period, turn on main breaker first then the pump breaker.
Jun 21, 2014 | Pool & Spa
I have an Intex 18x48 easy set pool and pump is shutting off/tripping circuit breaker after running for 1 minute for last 2-3 days. I called Intex (after reading questions posted here) and they are...
Pour some bleach (about 2 gallons) around the perimeter and give it a good brushing. May have to repeat in a few days. That should hold fine.
Jun 26, 2013 | Pool & Spa
Have a sovereign hot springs spa purchased in 2000. When turning the jets on it kicks the breaker. Also, the inside control system is not working anymore. Could our friendly electrician do this easily,...
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire.
If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Pool & Spa
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
Turn breaker on to hayward pump 1 1/2 hp model C48L2N134B1 just heard a humming noise and shut off
DIRTY START SWITCH OR AND COULD BE THE START CAPACITOR OR RUN CAPACITOR,. RUN CAPACITOR IS ON TOP OF THE MOTOR. I WOULD SUGGEST YOU TAKE THE BOLTS OUT AS PICTURED AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING.. SEARCH YOUR AREA FOR HIM ..JAY LONGWOOD FLORIDA
May 22, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
119 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
