Question about Hitachi 1TB External USB 2.0 Hard Drive
Hitachi xl 100 external hard drive is beeping. My Wii wont read it
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I need to reformat my Hitachi XL 100 as Time Machine will not connect. How do I do this on a Mac?
Find and open the application Disk Utility under Applications Click on the external drive and click Erase.
If you would like the drive to be compatible with Mac only, choose any of the Mac OS options. If you would like the drive to be compatible with Mac and Windows, choose FAT32.
Feb 26, 2014 | Hitachi Computers & Internet
Wii wont read the external hard drive
The Wii doesn;t have any built-in capability to read hard drives. You willo need to check with the author of the homebrew program you are using for help.
Mar 19, 2013 | Nintendo Wii Console
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
How do I get my Hitachi xl 1000, 1TB HDD to read on my computer? I turn it on and plug it in and all i get are loud noises from it and the occasional beep, It wont read
  • Does your computer kind of pause and acts like it thinking about connecting to the drive? If you go to the My Computer icon (on your desktop or in Start), and click over it to get the drop down menu, and find/click the "Manage" menu selection. Once the system manager starts, click on the Disk Management. See if your Hitachi drive is listed as "uninitialized" or if it shows up at all. If the former, then consider initializing it (assuming this is a new disk).
  • Otherwise, it sounds like a bad drive. Usually, modern drives produce a either a beep or a snap/click when you first turn them on. Afterwords, it should be a low level hum, some are barely audible. If the loud noises last more than 5 seconds, or sound like something is grinding against something else, you should return it, if it's under warranty.
  • If it's out of warranty and has data, you might consider some company that does data recovery from dead drives. But they tend to be expensive.
Feb 23, 2011 | Hitachi Computers & Internet
I connected my Hitachi xl 1000 external hard drive and my computer is not recognizing any new drive. The drive is working, the light is on, and I can hear him work, but wont be recognised by my laptop.
Try another cable and make sure the connection is in all the way. Also try it on another port or computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 01, 2011 | Hitachi Computers & Internet
My external hard drive continuously beeps and makes a clicking noise. Also, no computer is able to recognize this external hard drive.
The spinning mechanism on the HDD is failing meaning it can't read data of the platans. Unfortunately you need to buy a new one as this one can't be repaired.
Dec 29, 2010 | Hitachi Computers & Internet
I was able to use my Hitachi xl 1000 external hard drive on my computer and I wanted to be able to use it for my Macbook Pro as well but as soon as I used it for Time Machine Backup I wasn't able to use it...
If the MAC formats the external hard drive then the desktop cannot see any files on the hard disk even though it detects the external hard drive.
If you format the external hard drive using the Desktop computer and format it in FAT32 then the MAC can read and write to this hard drive and the desktop PC can also read and write to the external hard drive.
MAC computers can read and write on PC formatted disks but not the other way around.
Jun 29, 2010 | Computers & Internet
Mi wii wont read any games even if there clean how
Your disc drive will need to be replaced, or you can mod your wii system at www.wiihdmods.com and get 100 wii games playable from a hard drive for 150.00
May 07, 2010 | Nintendo Wii Console
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi 1TB External USB 2.0 Hard Drive Logo
1,702 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
