Question about Kenmore Oasis HE 27082 Top Load Washer
Mother board scans
Our washer is less than a year old....we have had it serviced 4 times already and the mother board replaced 3 times....the washer will start..run for a couple of minutes then numbers start scanning up and down and all over the place..we do not get codes....just a washer that does not seem to know what to do.....it will go into spin, stop, start...whatever its little brain seems to want to do at the moment...these problems started when the washer started itself up twice in the middle of the night....we had to unplug it....bizarrre....Sears seems happy to keep sending people out to replace the mother board ...however it is obvious the problem may be electrical...we have installed a dedicated surge protector...we had our electrical checked...we are not the problem...the last tech said he doesn't want to come back here again....he is sick of our washer...so....it is still under warranty...we will extend the warranty so Sears can send out a tech till the cows come home if they want...so far these visits have probably cost Sears the cost of the washer and more...time for Sears to replace it......we are fed up ...
  • debi55 Apr 28, 2008
    hii oldfixer...i made such a dumb mistake...guess i selected the wrong make...the washer we are having all the problems with is a Kenmore Elite-Oasis top loader HE washer...it doesnt have an agitator........hope i haven't just confused everyone...dont want to give a machine a bad rap that doesn't deserve it...
    thanks for your effort to help.....it will be amazing if it gets fixed through the efforts of experts on line rather than a Sears technician...appreciate the help....
Just called Sears to talk to a technician just about if it can just spin instead of rinsing and spinning. Told me it can't . Been wanting to know for a year now how i can just spin some hand washables without taking 20 minutes of re rinsing draining and then spinning. She knew nothing . Told me it can't be done . had to find out myself. Just press rinse/drain spin and then press 2nd rinse after that. They are of no help!!
Posted on Apr 28, 2008
    Genius:
  • 1,028 Answers
Possible issue with key or otherwise know as user interface..it is actually a conbination of keypads and electronic componets..pad could be stuck or actual interface computers scrambled
Posted on Apr 27, 2008
Have an Amana NAH6800, I must unplug it and plug back in to get it to start wash cycle. Also, keybord is locked until a couple of minutes after the wash cycle starts. Called repairman, he said control...
WELL IT IS POSSIBLE THE SECOND CONTROL BOARD WAS BAD ALSO? A 6 YEAR OLD WASHER IS YOUNG U CAN GET A GOOD 10-15 YEARS OUT OF A WELL KEPT WASHER.
Dec 03, 2014 | Amana Washing Machines
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
Machine won't rinse
Well, you could simply set it to wash again without detergent, if you haven't already thought of that.
Modern machines like yours operate from a computer like mother board that may have corroded the link to make the machine rinse only. Try that and see if that works, assuming your machine has that option on the selections. If your machine is less than two years old it should be under guarantee, but sometimes a repair outlet can convince the makers to pay for the repair or replace the unit for a new one. If it's made in China, it may become faulty within two years. I have personal experience with that problem. In the past 4 years, I've had 3 new machines, all made in China. I didn't have to pay for a new one or for repairs, probably because I threatened them with court action.
Jim Hart
Jun 20, 2010 | Kenmore HE2 Plus Front Load Washer
F1 appears after you press the start button
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
HE5 frontload washer error f11
F11 error code indicates a communication problem. The communication between the Central control board and the Motor control board cannot be sent correctly.
Potential causes:
1. Loose connections between the motor control board and the machine control board, or at
motor
2. Machine control board failure
3. Motor control board failure
4. Motor failure
5. Door lock failure
If this answers your problem, please rate my answer.
Thanks,
David
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frequent interruptions of washer
This is most likely the brushes on the motor. Intermittently failing due to wear and tear. I *could* be the motor but the brushes are very cheap in comparison.
On most washers the brushes are < £20. Time to fit is less than 0.5 hours.
You have three options
1/ If you are or know someone who is very technical and confident - once you have the right parts should be able to install them. (Unlplug the unit before touching!!!)
2/ If you have a service contract use it, they should provide parts and fix.
3/ A service engineer is your last option - say £90 callout + parts. (On certain washer units parts are free up to five years old - but you have to pay the call out fee)
Please dont forget to rate me, thanks!!
Mar 17, 2008 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
95 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
