Question about RCA F32689 32" TV
Service manual needed for a f32689 rca set chasis number ctc-197cr1a what i need is the service manual or the value's needed for the power supply as that is the problem with the set so if i can get a copy of this i would be most greatful............
  • 2,326 Answers
Click here for a free download. The power supply section should be very similar to your chassis even if it does not have the "cr1a" at end.
Posted on Apr 28, 2008
    Master:
  • 788 Answers
    Genius:
  • 1,665 Answers
Need r 114 u resistor
I have the schematics for this TV but the only resistor I see is label as R4114 and its value is 10K ohms, 5% 3 watts.
I could send you the schematics.
Let me know if you required further assistance.
Apr 07, 2010 | RCA F19207BC TV
RCA TV Model #f35673MB. I need to replace the coaxial cable jack on the back of the TV. Where can I get a replacement part.
If you are proficient to service the set yourself, you should contact any RCA service rep, and ask them to sell you the parts.
Take care, that the antenna connection must be serviced in a manner where electrical islation from the power supply chasis ground is maintained. This can be verified with a DVM. The ground isolation is a very serios safety issue.
If you are not experienced at servicing TV sets, mainly for safety reasons you should have your set serviced by an authorised service rep.
Jerry G.
Jan 23, 2010 | RCA Televison & Video
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
Wasn't able too get????
I was not able to find that service manual.
Check this one out.
This guys have it but is a bit expensive.
Apr 30, 2008 | RCA F32689 32" TV
Hi values needed
Click here to get the part you need. You can also call them for the parts you need.
RCA only gives their part number and not the generic one.
The parts list should have the resistor as well.
Apr 29, 2008 | RCA F32689 32" TV
Line across picture
A thick, drifting line across the screen indicates an open or leaking capacitor in power supply. Needs service repair
Apr 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power supply
Hi have a nice day!
Check if new fuse is of same type that is needed ie 2A , 2,5A as manual says. dont put different.
If you put correct fuse and blows then there is a short circuit at power supply area or after it and your TV must take to a qualified repair shop.
If you are familiar with electronic repairs write me down make and model to look for a service manual available.
Mar 18, 2008 | Televison & Video
Possible picture tube problem
Sounds like the tech you had there isn't too familiar with the CTC chassis. I doubt that your problem is the CRT. RCA ctc chassis have a problem with the tuner grounds breaking and this allows pulses to spike on the data control lines for the eeprom which can reprogram it and cause just about any problem from a dead set to a perfectly normal set and everything in between. First this should be eliminated by opening the tuner cover on the bottom of the board and resoldering the 28 connections if necessary. If the tuner is ok then it sounds like the paramaters in the service menu should be checked. There is no perfect number to set the paramaters to. It depends on the characteristics of the unit and is different on each set and determined by the tech. The service manual gives a procedure but I've been doing it so long I can get the drives close enough by using the black in the picture as a guide for the individual drives (raise them till you see the color in black areas and back off till it just goes away). In most cases this is more than satisfactory. If the paramaters do not solve the problem you probably have a componenct failure. It should not cost much to repair no matter what it is. First get a new tech, one that is qualified, to look at it. Good luck.
Jun 12, 2006 | RCA F35317 35" TV
RCA F32689 32" TV Logo
193 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
