Question about Hotpoint Refrigerators
I need a right hand salad drawer for my Hotpoint mistral fridge/freezer
SOURCE: my hotpoint mistral fridge/freezer is
Hi. I had the same problem (funnily just as my warranty had run out) hotpoint wanted about £90 plus parts for a call out. You need to replace the Yellow thermistor in the freezer compartment (quite easy with a cross screwdriver and thin fingers). I got mine from Uk White Goods for about £20 they give advice too. Solved it instantly. Thanks HOTPOINT, wont be spending £600 with you again. Good Luck.
Posted on Aug 07, 2008
  • 139 Answers
SOURCE: my fridge freezer Hotpoint Mistral
E8- Evaporator thermistor short circuit
Well this is a sensor,, found in the freezer compartment of the f/f
what you have to do is reove the draws fro mthe freezer and you will c a panel which has 6 screws., remove the panel and and you will c a fan, toward the right of the fan you will c a yellow plug with a bit of wire on it,
This is what you have to replace
try connect distributions you can find them on the net if your in the uk that is
hope this helps
cheers
washdoctor
Posted on Aug 25, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
co7196
  • 3433 Answers
SOURCE: the fridge on my bosch fridge/freezer keeps freezing all my food
This, as with the on off complaint on a bosch, sounds like your thermostat is n't paying attention. Turn it up, then slowly down and feel for any irregularity. If there is looseness or rough, like hsngin up its the thermostat. At least we know the bulb goes out when you close the door. Good Luck
Posted on May 25, 2009
  • 28 Answers
SOURCE: Hi i have a hotpoint mistral plus fridge freezer,
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Posted on Jul 23, 2009
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
BEKO CG964 fridge/freezer - base of fridge flooding with water underneath salad drawers
I had the EXACT same problem. I've just used a wire coat hanger and pushed it through the hole that the plunger couldn't impact and all the water drained out perfectly! Problem solved!
Jul 02, 2012 | Refrigerators
How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
My hotpoint mistral fridge/freezer is freezing very will, but ther fridge is not cooling. What could be wrong?
Jun 20, 2008 | Refrigerators
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
78 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
