Question about Haier ESA3125 Wall/Window Air Conditioner
Water is dripping from corner of unit that is inside the house, going down the wall and making the carpet wet.
  • 1 more comment
  • Bob Sloan
    Bob Sloan Aug 05, 2010
    have you tried balancing the unit with the rear of the ac tipped downward?
    All AC's extract water and need to be positioned to allow the water to drain out. If yours is tipped too far forward that water will drain to the inside.
  • jbreinhart6 Aug 05, 2010
    The unit fit into a sleeve that was already in the wall with the old air conditioner we had. The unit has been in for several years without this issue being noticable. I can try to wedge soemthing under it at the inside edge of the sleeve to see if that is all it is. Let's hope so.
  • Bob Sloan
    Bob Sloan Aug 06, 2010
    Restating my clarification as a solution doesn't help at all.
    President:
  • 3,773 Answers
Check your drain
also make sure the unit leans a little tilted
Towards the back
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 05, 2010
My 5200 wall air conditions works fine but leaking water on lower left corner down my wall inside my house. Already cleared outside drain hole and is dripping but can't reach or see the inner drainage...
The outer drain hole is the only one that needed to be cleared. But, keep and eye on it, as there may be some floating debris in the drip pan. You said the unit is angled enough at the rear. So, I'm assume you have at least 1/4" to 1/2" downward tilt at the rear of the unit. If that's the case, for now, that's about all you can do. Unless you have a Wet/Dry Shop Vac. In which case you could **** the water out of the drip pan after removing the front panel of the unit. If you attempt this, be sure the Master ON/OFF switch on the unit is OFF and the unit is unplugged.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Kenmore Single Room Air Conditioner
My 2003 toyota camry on the driver side front floor matt, the carpet is wet. It is wet even though we have had no rain. and is hot.
Could be the A/C drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the cab. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, its been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the cab. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean.
Aug 03, 2011 | Toyota Camry Cars & Trucks
On my LG window AC Md. LWHD1009R, I cannot find a drain hole to let the water out. The back bottom of the pan was filled water containing a rusty sludge, but the heat exchanger coils are aluminum, so it...
usually in the middle underside of the window units is a hole that water drains out of, you can always drill new holes in order to make it drain, Good Luck Tim
Apr 24, 2011 | Heating & Cooling
Rust colored water is dripping down outside of house, and when unit is on it sounds like constant water dripping.
condensation dripping out of my central air unit is dripping a rust colored water that has stained my house. What is causing this?
Aug 05, 2010 | Frigidaire FAC124 wall/Window Air...
Carpet wet under window air con.
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Jul 15, 2010 | Maytag M7X05F2B Air Conditioner
Water is dripping from outer heater unit and soaking passanger side of front carpet.
There are two causes of fluid dripping from the heater core/ac evaporator housing. First, if it is running inside the vehicle and getting the carpet wet as described then it is most likely a bad heater core leaking antifreeze into the cab. Secondly, if it is dripping outside only when the a/c or defroster is running then it is the normal expulsion of condensation and is harmless.
May 27, 2010 | 2003 Saturn L-Series
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Dripping air conditoner
The "drip pan" is actually the entire base srround of the unit. There are two critical things you must confirm 1) is the unit angled back to the outside(you need water to flow away from the inside) and 2) there may be a plug/obstruction in the outer casing where the water is intended to drain from. You should check to see if either or both of these conditions exsist.
Aug 19, 2009 | Heating & Cooling
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
Haier ESA3125 Wall/Window Air Conditioner Logo
87 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
