I have been using Maxtor basics desktop 500mb with my desktop PC (XP) for a year. Now I have an Apple Mac Mini and so I want to use the Maxtor with the Mac and access the files on it from the Mac (OX Snow Lprd) . The Maxtor paperwork says that connecting it to a Mac will trigger a reformat decision. Will that not then erase all the files already in the Maxtor (the opposite to what I want to achieve)? Thanks for advice H-T
    President:
  • 2,571 Answers
Looks like you may not be in luck.
I found this on a forum.....
When you have the hard drive connect to the Mac, right click on it's icon and select Get Info. Look in the window that pops up and see what is listed next to Formatting. It it says NTFS, then the Mac can't write to it. Being it is a large drive, that you have been using on a Windows PC, I'm 99% sure it is NTFS. In order for the Mac to write to it, you will have to erase and reformat the drive. If you will only now be using it on the Mac, then you can format it Mac OS Extended (Journaled). Just remember, that by doing so Windows now will not be able to read or write to the disk. If you do need it to work with both platforms, you will need to see if Maxtor has a utility to do the formatting. Because of it's size, I know that Windows will not format it FAT32 (which is the format you need it to be in for both OSes to read and write to it) in one drive as Microsoft has limited FAT32 formatting to only 32Gb, but can read FAT32 drives of almost any size. The Mac can format MS-DOS (FAT), but I have not had the greatest luck in formatting large drives with it. The Mac will see and read/write just fine, but many times, Windows will not see the drive. I know that most drive makers do have a utility that runs under Windows (some even have Mac ones) and will format it for you in FAT32. There is one downside though, you will not be able to have a file greater then 4Gb in size due to a limitation is the structure of the FAT32 data table
Posted on Aug 05, 2010
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
What year was my mini mac serial # co7j5806djdo manufactured?
Hi Elytta, hope this is some help
https://itunes.apple.com/au/app/mactracker/id430255202?mt=12
Mar 18, 2013 | Apple Mac mini G4 Desktop
Bought mini mac used no disk and start up password
If you have no disk call apple or go to apple store and they will get you one.
Mar 18, 2013 | Apple Computer Apple Mac mini 2.66GHz...
How to Connect Maxtor OneTouch 4 Mini 320Gb to PC
I have one as well running along with a PC. PCs and Macs are formatted differently. Go to www.maxtor.com and create a search for reformatting from a Mac to a PC with your Operating System in the search as well. Should have no problems after doing that. It will tell you and or show you where and how to reformat.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Oct 01, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Harddrive is not recognisable by both PC and MAC.. Its either one or the other..
Partition the drive into 2 250 Gig partions, Call 1 partition MAC and the other one name PC, for the apropriate partion on each machine
Apr 13, 2009 | Computers & Internet
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Web camera use in apple pc in windows xp
When youre running windows XP on a Macbook, you should install the Bootcamptools from the original Mac OSX Leopard DVD. This installs all the components of your Macbook including graphics, Bluetooth and of course the iSight =)
Jan 20, 2009 | Apple MacBook Pro Laptop Computer with...
From apple to windows
You did not mention which Windows or Mac version you are running, but "in the good old days", all I did was to format the drive either as FAT32 (in Windows) or as MS-DOS (in Mac).
Keep volume/folder file names following Windows naming rules.
Don't erase any of the invisible files that will be visible on the opposite system when running. MP3's will write/read fine for both OS.
Jul 20, 2008 | Maxtor 160GB OneTouch III Mini USB 2.0...
Installing ram upgrade
Pharlap33
YOu have to carefully, separate the 2 little brackets and place the new ram into it. it should work if you do carefully of course.
the idea is put it in the slot carefully.
Dec 05, 2007 | Apple Bundle Mac mini 1.66Ghz Intel Core...
Computers & Internet Logo
73 people viewed this question
Alun Cox
David Payne
David Payne
