Question about Vacuums
I have a vax spin scrub V124. The brushes won't turn. I've cleaned the filter etc, but nothing.
reddevil6
  • 1673 Answers
SOURCE: Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Posted on Jan 14, 2008
renevacdoc
  • 84 Answers
SOURCE: spin-scrub brushes do not spin
hello. there is a little window by the brush control. if you open it up, you can see that there is maybe some lint covering it. scrape that off, and try again. make sure your lever is set to brushes and realease the handle release. if this doesn't work, then you probably have a problem with your gear box. this can only be serviced at a repair shop. I hope this helps. Let me know! Thanks, Renevacdoc
Posted on Jul 24, 2009
ThinkVacuums
  • 144 Answers
SOURCE: Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Posted on Aug 25, 2009
  • 57 Answers
SOURCE: the scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Posted on Mar 10, 2010
  • 1558 Answers
SOURCE: Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Posted on Jul 18, 2010
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Vax Problems> The front brushes on my Vax V124
before it stopped working did it smell like burnt rubber at all if so its the belt
Jun 05, 2013 | Vacuums
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
Roller brush not working on vax air mach 6
Hi I have a vax mach air light.the brushes wont turn but the green light is on. I have checked eveything .The little button on side tube no blocks .Checked all filters.
Jul 07, 2012 | VAX Appliances Vax X3 Bagless Upright...
What can be done with the scrub brushes not working, not spinning.Ihave cleaned the filter etc.
I you are unable to turn them by hand while in the machine, then the turbine requires service. this I would recomend an authorized shop to address.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on,...
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Jul 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction on carpet
make sure the brush is spinning and also make sure u there is not a clog right behind the canister when you detach it from the vacuum itself
Jan 18, 2008 | VAX Appliances Vax X5 Bagless Upright...
Vacuums Logo
691 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
