Ew 100 g2. Im needing the sponge filters that go inside . I need 4 of them. How much are they?
  • 146 Answers
You can cut your own from regular air conditioner filter found at any hardware store.
Posted on Aug 05, 2010
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
Issue more complicated than originally thought!
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
May 22, 2012 | Sennheiser 100/500 G2 Series Wireless...
Sennheiser ew 100 G2 cordless mic shuts off, low batt signal flashes , when fresh batteries are used. batteries inside mic heat up & get hot!
Heating up on replacing batteries is an indication of a short circuit.The construction of these cordless mic does not allow one to do any kind of repair. You will have to replace the whole circuit board which is available only with the authorized service center. And might cost you 70% the cost of the mic itself.
Jul 06, 2011 | Audio Players & Recorders
It appears the power on/off button has been pushed in or broken off on a wireless EW 100 G2 microphone. ID # 90913 Serial# 111619
Often the rubber button is pushed into the microphone.
You can easily disasemble the unit.
Just open the batterycase, you will find some small torx screws.
Regards,
Gerard
Mar 22, 2011 | Sennheiser Audio Players & Recorders
What would it cost to repair the on/off switch on ew 100G2 sennheiser ?
To repair the on/off switch of the handhelt it would cost abt 15 minutes and $2,00 for the switch.
So that would be $20-25.
Reagrds Gerard
Oct 03, 2010 | Sennheiser 100/500 G2 Series Wireless...
A sponge fell into the vent of my dryer. How do I get it out. Is it safe to run the dryer with the sponge in the vent hose?
If the sponge fell down inside where your lint filter goes, that could be a problem. It is entirely possible that the sponge was blown out of the machine and there is no problem at all. But, if you cannot retrieve it with a clothes hanger or anything like that, you will have to take the dryer apart. So yes, the sponge could cause a clog and clogs are bad. The hot air must be able to get out of the dryer and blown outside with the least resistance possible.
Taking the dryer apart. UNPLUG the dryer from the wall. Pull the dryer away and get behind. Remove the dryer vent and back panel (8 1/4 inch screws). On the left is the lint chute where the sponge could possibly be. Simply remove the 4-6 1/4 screws and take the chute out. Look inside for the obstruction :) If it is nowhere to be found, it made it out of the dryer. Check the vent behind the dryer and the exit of the house. If it is nowhere to be found it could be inside the vent going to the outside of your house. The vent needs to be cleaned at that point to get the sponge out.
May 26, 2010 | Whirlpool LER4634J Electric Dryer
Sennheiser ew 100 g2 handheld microphone loose coil in capsule?
I had a similar problem with a sure sm 57 that I used on a guitar amp. I don't know if this is the correct fix but it worked for me. I took thin strips of paper to use as spacers and placed them evenly around the coil. I used a hot melt glue gun and placed 3 small drops around the edge of the coil. Remove the spacers and the coil should be secure.
Joey Clay
Oct 24, 2009 | Sennheiser Evolution G2 100 Series UHF...
Sennheiser EW 100 G2
Warranty? If not, open it up and look for unattached wires. If there's none, look for parts that look damaged, usually brown-ish. if there's any, they need to be replaced. Might get lucky and find parts
Oct 14, 2008 | Sennheiser Evolution 100 G2 (SEN-EW152G2)...
Driver usb edimax ew-7318USg
please I need to driver edimax usb ew 7318USg becouse Im lost instal CD thenx George
Jul 02, 2008 | Edimax WRLS ADAPT| USB EW-7317UHG RT...
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
