Question about Sharp XR-10X Multimedia Projector
Sharp xr 10x
I havent use my sharp xr 10x proyector for about 4 months, i tried to conect it but when i turn it on, only the vent starts for about 2 minutes, then it just turn off by itself, non of the leds blinks or light on, how can i solve this problem. thank you
  • no tv gee Oct 20, 2008
    How do I open it up with out damaging the top gray cover
  • 3 Answers
You will need to open it up and flip this little breaker switch. It has gotten to hot and tripped itself. Dust it out while you are in there.
Posted on Sep 04, 2008
I have tried to reset the thermal switch on my sharp xr 10x, but the button has no resistance to it. Does that mean it is broken? Can I get a new one?
You should be able to get a new one from SHARP.
Does pressing in the button allow the machine to start up.
If not then the other overtemperature switches may have activated also.
The fuse may also be suspect
Feb 26, 2011 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 14, 2010 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
After 20 minutes of use picture shuts down. (Sharp XR-10X)
use canned air and blow every bit of dust out of every vent and hole. if you want to, you can remove the top (6 screws on the bottom, and the 2 top screws on the back) and blow dust out that way. i could also be a power supply problem. from excessive heat, the capacitors on the ps dry up and don't work as they should, causing shutdown.
May 24, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Sharp xr-10x projector wont turn on
if there are no leds lit on the top, then probably the bimetal circuit breaker tripped. you have to take the top off to get to it. it's located on the front of the lamp housing. press the red button. if it still doesn't turn on, it's the power supply.
Dec 22, 2008 | Sharp XR-10X Multimedia Projector
Projector shuts off sporadically
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
How do i connect my projecter with my pc
Your Sharp XR-10X will only allow video inputs through the:
1. RGB/ component input (15-pin HD)
2. composite video input (RCA phono color yellow)
2. S-Video input ( 4 pin mini-DIN )
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output (4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Dec 03, 2007 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
292 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
