Question about Euro-Pro EP278 Bravetti Platinum 1500 Watts Toaster Oven with Convection Cooking
Convection mode when in the convection mode, the whole unit makes a rumbling sound until the temperature is reached and the fan shuts off. I am trying out my second Euro-Pro Ep278 becaise the first on was even louder and kinda thumped also. I returned it with no problem. Is this the nature of convention ovens?
  • sja_jlengrs Aug 12, 2008
    same problem with very loud rackety noise and it doesn't stop!
    Scholar:
  • 53 Answers
I would assume that these ovens have a faulty fan motor mount or it may just be a bad design. I would go with a different make or model.
Posted on May 20, 2010
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
Convention oven just got one. too noise???? is this normal?
Convection ovens use one or more fans to move the air around the food, so they are typically noisier than other toaster oven units.
As long as you aren't hearing a scraping sound, which would indicate a blower that was out of alignment, then it should be ok. Generally, you will hear a loud whooshing sound, like a hair dryer.
Mar 05, 2011 | Black & Decker CTO7000 1500 Watts Toaster...
My bread burned on top before it was done ,using convection oven
I would say that it sounds like the bottom element isn't working. I am assuming that you can tell that the fan for the convection feature is running. You should be able to see through the glass door to see if the element is heating up.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 17, 2011 | Hamilton Beach Toaster Ovens
Convection Oven blows fuse. Replaced element. Still blows fuse.
could be anything
get in an electrician to trace the fault
Nov 03, 2017 | Toaster Ovens
When I plug in my Oster 6248 toaster oven, it flashes error
This is caused by a bad contact on the heat sensor located on the top inside the oven...now if i could juste find the replacement part...
Mar 14, 2010 | Oster Toaster Ovens
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Model 460/5 can not control the heat
I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
Mar 04, 2009 | Farberware T490C 1500 Watts Toaster Oven...
I have a new GE Covection Toaster Oven model 169127/169140. My question is should this oven's heating elements shut off periodically when the set temperature has been reached?
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 01, 2009 | GE 168947 Toaster Oven with Convection...
Convection setting loud noise
try going to the place u bought it and see if they can tell u what to do with it. better safe then sorry
Jul 17, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Overheating
Try CG Industries in Chicago, IL - they rebuild a wide variety of electronic thermostats. Their number is 630-216-5050.
Feb 08, 2008 | Waring CO1500 1700 Watts Toaster Oven with...
Euro-Pro EP278 Bravetti Platinum 1500 Watts Toaster Oven with Convection Cooking Logo
230 people viewed this question
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
