Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
I have a poulan pro bushmaster ppb300 and I replaced the carburator and I need help hooking up the gas lines. I don't know whick goes where. Thanks in advance
  • 279 Answers
SOURCE: Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Posted on Jul 14, 2009
SOURCE: poulan 2150 type3 / a show me diagran of fuel line
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
Posted on Aug 23, 2009
SOURCE: gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
Posted on Jun 01, 2010
vincob
  • 718 Answers
SOURCE: Type of trimmer: Poulan Pro
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Posted on Jun 04, 2011
hunter19_46m
  • 7482 Answers
SOURCE: put a new carburator on and don't know how to hook
Hi janemueller...
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Free answer...Please take time to rate me
Posted on Jun 19, 2011
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Put a new carburator on and don't know how to hook
Hi janemueller...
Jun 15, 2011 | Poulan Garden
ON a Poulan 220 Pro all of the fuel lines are
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Let us start with the bleeder. The 2 hoses that connect to the bleeder are different sizes (Important). If the nipples are the same size connect a hose temporarily to one of them and place the free end in a small container of mix (please be careful with open gasoline and as soon as it is no longer needed put it out of harms way.). Squeeze the bulb if it blows bubbles that is the return side, it gets the large hose and attaches to a fitting on the tank. If it appears nothing happens but when released fuel is drawn into the bleeder it requires a short section of small hose and attaches to one of the carburetor fittings.
A second small hose goes through the tank and connects to the carburetor just like the video including the filter. It feeds the carburetor like it has since before bleeders were installed. I am not certain which carburetor fitting connects to the tank or the primer, please leave them long enough to swap until the saw is running. Logic says the upper most fitting (air bleed) goes to the primer but that is not always true. The Poulan drawing is deceptive it appears the filtered line feeds the bleeder it does not!!!
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but are on different illustrations. They are also beneficial with disassembly/reassembly.
A link to a Poulan "PP220 Gas Saw Type 5 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
If your saw is not a Type 5 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan pro 335 trimmer that had the carburator off now i need to know how to put the fuel lines back on i have a new primer bubble but dont know how the fuel lines route back to the 2 ports on the...
OK the thing to remember is that this is a purge not a primer, so it pulls fuel from the carb and pushes it back to the tank, there is two connections on the purge a long one and a short one, the long one is pressure so this has a pipe back to the tank ( the one in the tank without the filter on) the short connection is the suction side so this goes to the carb the connection furtest from the pump cover ( the cover with a single screw in the middle )
Feb 12, 2018 | Poulan Garden
I need to know how to route the gas lines on a poulan pro 210 i notice the two sizes of line and there are two hookups on the carb which goes where
This should help. Snap a photo then a small sample of each to your local chainsaw seller.
The link is a Poulan Pro 210 IPL.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw you can find the correct one here:
Poulan.com
If you have more questions you can reply below. I hope this is helpful.
Lou
Jan 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How to hook up a carburator on a weedeater with a primer bulb
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 18, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Throttle linkage for Poulan 1950le
Most times the thottle wire end is "Z' shape. The end of the wire is passed thru the carburator throttle lever untill the wire is past the first bend, the wire is laid over so that the travel of the wire is parallel to the swing of the throttle lever. Many times both end of the wire are the same or one end has a taller mid section to fit thru the hole in the plastic (if it's plastic) hand throttle end.
Jul 01, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
171 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
