Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
I'm running a tape player into one of the mic channels, then out the tape out; problem is any stereo presence is lost. Is it possible to run a 1/8" to RCA in the RCA in, route that to the level meter/main faders, then out the RCAs, giving me an adjustable stereo signal? I have no problems on the mic channels but when I try the cd/tape in i cannot seem to get it to the cd/tape out in any way.
  • Behringer Master
  • 5,603 Answers
Each mic channel is MONO. You could use a 1/8 stereo splitter cable into two mic channels and then PAN them opposite to retain the stereo.
You can also use a splitter cable into the 1/4 inch stereo inputs on the mixer. The 1/8 inch plug must be a stereo plug that then splits to two RCA plugs or two 1/4 inch plugs.
Note that the manual specifies that the Tape/CD out is merely paralleled off the mains out. This means that your main fader controls the level to the CD/TAPE output... which may mean your main output has to be too loud to get adequate output from the CD/TAPE outs to be effective. This would require balancing the levels into your external amp better.
Posted on Aug 06, 2010
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
I have my pc hooked via 1/8" to 1/4' to my europower pmp518m and my sound is very low, but my mics are very loud (need music loud also)
The 1/8 jackon the PC is Stereo so you would need a stereo splitter to then go into separate jacks or maybe tape input on the PMP. Plugging in a mono jack shorts out one side of the PC audio out. Make sure you use a splitter type and NOT a 1/8 to 1/4 stereo cable. It must split into TWO cablles to plug into the PMP.
Mar 12, 2013 | Music
I have a mackie cfx12 mixer. I just added an eq with sub woffer crossover via the main inserts using the proper insert cables. System works great, however when Using a CD player the subs will not work. any...
Sorry, I have looked at the schematics and the TAPE IN jacks are mixed into the MAIN outs AFTER the insert jacks, so your subs will NOT receive signal via the insert from the TAPE IN jacks.
You could make a small passive mixer merging the TAPE/CD before going to the crossover. This would require some non-standard cabling.... The other option is to run the CD into a regular stereo channel rather than the TAPE IN jacks... then the CD will go through the insert/crossover and to the subs as you desire. The last option is to use the crossover at the MAIN outputs instead of as an insert... which would be the CONVENTIONAL way... use BALANCED cables wherever possible.
Jul 22, 2011 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
Have a Behringer 1202 Xenyx FX, balanced cable into a new windows 7 PC and keep getting hiss. When I raise the gain, mic or master volume the hiss is more awful. my internet broadcasts sound awful. what am...
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Jul 10, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
Cant hook computer to mixer for you tube music
You would need a stereo splitter taking a 1/8 inch stereo plug for the computer into two 1/4 inch jacks to plug into two channels of the mixer OR a 1/8 to 1/4 TRS cable that you go into the Stereo (L) of one of the stereo channels... OR a 1/8 inch splitter to RCA plugs going into the TAPE input jacks of the mixer. You can't really go via the USB cable easily from YouTube,
Mar 30, 2011 | Behringer XENYX 2442FX Mixer
Hi, I cannot get stereo signal from my mic. I used the recording level L/R knob correctly, but when I go to the left side, there's not signal at all. Should I use a different type of cable? Thanks,...
You mention "mic"... to do stereo you need two mics...
If you are trying to "PAN" a single mic, then you should use a WYE cable and have the single mic go to both input channels.
Jan 17, 2011 | Korg Mr 1000 1 Bit Professional Digital...
Hook up eventide harmonizer to the pmp 6000
There are many models of the Eventide and how to hook them up will vary and depend if you have multiplle mics that are to be serviced. If you have multiple mics, I would be tempted to run the mics into some of the channels of the PMP but tur their faders to zero and send them to MONITOR 1. Come out of the MONITOR 1 jack to go into the Eventide and then run the Eventide into one of the line inout channels like 19/20. You would need to use balanced connections and some adapters from XLR to 1/4 inch to make the connections. There are MANY ways to configure this and depends what you are trying to do. If all audio is to go through the Eventide, then wire it as an "INSERT" for the power amp. This would require a special cables.
Jan 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
We are trying to use the Karaoke Machine and the words don't display. And we don't see any audio input to connect the ipod.
You would connect the IPOD to the RCA jacks on the back, HOWEVER the audio through there cannot be used for Karaoke. Te only other possibility is to mix the stereo channels of the IPOD and run them into one of the MIC inputs.
To get words, you must buy special Karaoke CD's that have the music and the lyrics. Search for sellers of the disks using Google.
Dec 27, 2010 | GPX Karaoke Party Machine
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
How do I adjust the volume when I plug my mp3 player in to the phonos with out the main slider
In a word, you DON'T... The main fader is the ONLY volume control in the loop going into the TAPE inputs.
If you need another volume control, then either use volume control if availlable on the tape/MP3 player.
Your other option is to use a splitter cable from the MP3 into one of the stereo input channels which do have level controls.
Now if you want to have the tape input level INDEPENDENT of the main slider, that is not really possible either. Adding a mixer AFTER the mains could accomplish this, but that is extra hardware.
Aug 06, 2010 | Behringer XENYX 2442FX Mixer
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
88 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
