Question about Belling 335 Electric Kitchen Range
When I turn main oven on there is no light and left back ring doesnt work all other hobs and grill does work
    Sergeant:
    Champion:
  • 277 Answers
Hi Mark,
Do you mean when you set the temperature.on the oven you do not see the oven element light up or are you saying that the light for the oven doesn't work?
Well, if you can't see the elements working then it could be the element. The light bulb is activated by a switch on the console.
The top burners may not work because of Infinity switches. They usually go before the elements.
Are you good with a mltimeter? Are you in the GTA ?
If in the GTA, I can help more
bweazer@yahoo.ca
Posted on Aug 05, 2010
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
Smeg oven UK80MFX1 troubleshooting
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 30, 2011 | Smeg Ovens
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 | Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
I have a very old tricity double oven with a top part and bottom part of the oven it doesnt have a hob as thats separate.It has three nobs to the left that are for the grill, the lower oven and the main...
I think I might have a manual for this oven! Is it a built-in job with the grill at the bottom and main oven at the top, made by Thorn Tricity?
Aug 07, 2009 | Ovens
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Beko dc543 oven and top left top right bottom right hobs not working bottom left hob is working and so is grill i have checked all terminal wires and all ok i had this problem before under...
I AM NOT AN ELECTRICIAN ! But i have had the same problem of the oven and the back right ring not working and have found the cause of this. For some reason there is a thermal fuse running inline on a live wire inside the cooker if you feel competent yourself in replacing this fuse you will save a good deal of money on call out fees, here is how to do it. SAFETY is the crucial, First of all isolate the power source to the cooker, pull out cooker so you can get access to the back of the cooker, remove the 9 screws ( i think there is 9) to remove the back plate from the cooker, this is quite heavy because there is a small block of concrete fastened to the bottom left hand side of the back plate, looking at the inside of the cooker on the right hand side you will see a white wire which has been secured via a small screwed clip, this wire has a transparent sleeve covering the thermal fuse, remove the sleeve by sliding it up or down the wire, check the fuse by with a meter just to be sure, if it is blown cut the fuse out. replace fuse the same way it was fitted. replace the sleeve and fit the back on the cooker SAFETY FIRST switch on power and try oven and back ring, mine works fine. like i said at the start i am not an electrician, but i can not understand why there is a thermal fuse running inline to the oven which is linked the back right hob. all the best folks Hobbo from Chess.
Mar 23, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Belling 335 Electric Kitchen Range Logo
262 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
