Question about Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches I have been having problems with skipped stitches. When I first got the machine everything worked fine. But on the last few quilts I can't prevent skipped stitches. I have changed needles, thread, tension, cleaned, you name it I have probable tried it. I think my problem is timing. How can you adjust this?? Thanks
  • Hestine May 29, 2008
    Hi
    Yes, I've got the Janome Delux DX a very old machine. My machine don't catch the bottom thread. I've changed the needle and set the timing @ the bottom with the bobben. What else can I do?
  • 3 Answers
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Posted on Aug 29, 2009
Tl2000 and it is skipping stitches while quilting. I have changed the needle. I used needles 14 16 & 18 I have cleaned the machine. When I sew seams I have no problems.
Have you changed the type of needle--top stitch, embroidery, microtex? Sometimes that will help. Also, my skipped stitches occur in FMQ because the fabric is moving too fast for the machine speed or I have a jerky movement. It helps me to try slowing down the fabric movement or speed up the machine and practice making smooth, consistent movement. I've never done FMQ with a needle larger than an 80/12, so you might try a smaller needle to reduce the fabric grabbing the thread.
Skipping the Skipped Stitches in Your Free Motion Quilting
Skipping Stitches
FMQ Troubleshooting Tips Tricks
Oct 31, 2017 | Sewing Machines
CANT QUILT WITH MY JUKI TENSION PROBLEMS
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into trouble...like spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are using...like is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Basic Maintenance Tension Skipped Stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
10 reasons for skipped stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
Skipping stitches, already change the needle what else could be?
What to Do If Your Sewing Machine Is Skipping Stitches
www.craftsy.com > Blog Home > Quilting Blog
Jan 22, 2014 - Skipped stitches when you'e in the midst of sewing are really aggravating, especially when they occur on highly visible topstitching. But don't ...
Four Tips for Solving Skipped Stitches - YouTube
? 1:49
https://www.youtube.com/watch?v=djJXwsUM8YY
Sep 30, 2013 - Uploaded by How To Sew
Visit www.howtosew.com for more sewing basics and easy p. ...Sewing Machine Repair Interview- Common Problems w/Stitches, Threading, ...
Jan 27, 2016 | Sewing Machines
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
I have a pfaff grand quilter and have used it to do six quilts and has worked great but the last quilt i did the top thread kept breaking every few inches i have tried everything but in the end took it in...
I had a similar problem with the long stitches. One of the encoders for the stitch regulator was not turning all the time when I moved the machine. My dealer gave me a new one and now the machine works fine. It could also be your cable from the encoders to the machine. If the wires (very fragile) get broken, either the machine won't sew when you go side to side or back and forth, or it will make the intermittently long stitches you mentioned.
It's important to have the foot raised when you thread the machine. If you have it down, the thread won't get caught between the tension disks, and it will be very hard to get consistent stitches.
Jun 15, 2010 | PfaFF Sewing Machines
Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Sep 19, 2009 | Husqvarna Freesia 425
When machine quilting sews fine when moving forward, skips stitches when moving away
Check your needle. Make sure it is not blunt, try a Size 90 Topstitch needle or Embroidery needle. If you are using a thread thicker than regular piecing weight, you need a needle with a larger eye and a larger scrarf - the hollowed out bit at the back of the needle. Also don't sew too fast nor change direction too sharply. If you need to do a sharp turn, let the machine "mark time" once at the turn before moving off in the new direction.
Pam
Apr 28, 2009 | Sewing Machines
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
436 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
