Question about IBM Infoprint 1532 Laser Printer
Can't stop printer form printing this one page over and over...
I think someone has played a trick on us and our printer is printing the same page over and over , i tried a - calcel a job button, however there are thousands of ports, then i tried the - reset the printer button and it didn't work, so how can i just delete all the jobs in this printer ?Any suggestions?
You might want to check and make sure it's not printing the demo! If that's the case someone just has it in demo mode and holding down the green button while booting might do it!
Posted on Oct 28, 2008
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Not the right format in the settings
In windows-Start menu - Settings -printer & faxes - Select your printer - right click - select server properties - give your desire form name - set your page hight & page width-save the form.
This the procedure to create a new form.
Oct 29, 2008 | Tally Line Matrix T6100 Printer
Printing
It sounds like the 'form length' is misset.
Check the initial setup settings.
Aug 20, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
IBM Infoprint 1532 Laser Printer Logo
54 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
