Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My saltwater system keeps reading that my pool has low salt however I tested my pool and it has way to much salt. Also I have 6way testing strip and I don't know how to read it. I don't know what way is up and which way would be down.
  • 297 Answers
Just match the colors on the strip
you should at least have a few close ones that would indicate which way to hold it
As for salt, I hope you are using a test kit for salt that reads #'s not colors
you need to be as close to 3000ppm as possible
under 2700ppm and you will not produce enough chlorine and trigger alarms any higher than 3500 and you will trigger alarms, could go cloudy, and also cause corrosion on metal parts like an aluminum ladder
The system can read backwards like if it is high salt showing it could be low or the other way around.
The system only really knows there is a problem
just remeber 3000ppm
If you are over 3500ppm start by draining 20% water and refill and filter only for 6 hours until you get it back to 3000
once in the paramiters I mentioned clean your electro cell and start the system
Posted on Aug 05, 2010
My Salt water pump keeps saying it is low on salt. I have added plenty of salt.
What is plenty of salt? There is a specific amount that you need Can't guess at it.
You must be above 2800ppm and no higher than 3800ppm
3000ppm is the best
You will need test strips for salt that reads in numbers not color
High salt can also trigger a LOW salt alarm
Don't ask me, it just happens
Just remeber 3000ppm
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
I just bought a saltwater system for my 12x39 pool a month ago did start up like book said and pool was fine for a month then the low salt light came on so i put 15 lbs of salt in per instructions kids...
you really should get test strips for salt. Get the kind that reads #'s
Get your pool to as close to 3000ppm as you can. any lower than 27000 and you do not generate enough chlorine any higher than 3600 will taste bad and could trigger high salt alarm 3000 is best
run filter only for a few hours before running generator the salt needs enough time to fully distribute through the pool
Jun 30, 2010 | Intex Automatic Salt Water System for ...
I am getting a 0 reading on my copper and chlorine reading strips and i have ran my filter correctly for 6 days now
if your salt is too low you will not be able to generate chlorine.
Get a test strips that has #'s on the bottle not color strips for salt.
get it to 3000ppm filter only for 24 hours then try to generate
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
System reading low salt
get a salt test strip kit
you want to be as close to 3000ppm as possible let system run on filter only for at least 24 hours before trying to generate chlorine
Jun 11, 2010 | Intex Automatic Salt Water System for ...
Intex 3-way test strips
I use my 3 way test strips and copper strip when the pool is not running After 15 seconds the readings are using a bit high. After 3 - 4 minutes the readings are perfect.
May 09, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
244 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
