Question about Kenmore 95002 / 95004 Electric Kitchen Range
There is a red light visable thru the glass top on the left rear of the cooktop. cannot find this light anywhere in the book. it is on and has never come on befor
    Sergeant:
    Champion:
  • 277 Answers
Yeh,
I ve seen this before.
Try turning on one buner at a time. Make the element red hot!. If one does not get red hot. make a note of that switch.
Some stoves create a way for a technician to know which switch is shorted and uaually it is the one that doesn't get red hot.
If all buners are red hot , preheat oven for 350 and wait. it should take 5min to heat up oven. if oven not hot ,one of the elements is blown
Posted on Aug 05, 2010
My elements are off but the red light is still on?
Red light will stay on until burner temperature is down to a safe level.
Oct 02, 2016 | Frigidaire Stove/Oven/Range Black Glass...
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
Can the glass of a whirlpool cerano hob suddenly crack?
You didn't need 'red hot' to simmer. When you got it red hot, and then put the pan on it, the pan sucked the heat out of the ring to fast, and caused stress in the glass causing it to crack. Tops are meant to be used the way you used it. Your fault I am afraid.
The top can be replaced.
Sep 19, 2016 | Whirlpool 30" Schott Ceran Surface...
Cooktop light doesn't shut off
The temperature sensor located on the that element is failing. the sensor red light reminds you that the burner area is still hot. The light should go out once the glass top has cooled,but the failing sensor won't allow it. A slight rap with your hand on glass top over that burner once cool will put the light out. It more than likely continue until the unit is replaced.
Jan 20, 2013 | Whirlpool Accubake RF362LXTT Electric...
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
How can i change the glass surface on a cooktop jenn-air
Hi I have changed out the maytag and it takes a little time but it is easy to do ,
but costley, First of all turn off power or unplug unit, open the front of this unit and you will see to small screws top left and top right side, after removing the two screws then lift the top from the front, then all the wires will be visable to you, if you are not able to remember all the wires where there go then mark wires with masking tape or you can take a picture if you have a camara that you can use . like i said it is easy fix just take your time >
Sep 30, 2011 | Jenn-Air JED8430 Electric Cooktop
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Left a empty pan on hot burner and glass top turned smokey under glass and left tiny pit marks on surface the color of the top is black
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Amana AKT3650 Electric Cooktop
Cracked cooktop on Kitchenaid built in cooktop
oh im sorry about that.yes you can purchase a new one.i would shop one line because more competition and then would get a better price you will need model and ser# .just check them out before giving your money.ive sold some last year thru sears as a tech and they were about 400$.you can find a glass top range on sale for about that much,but wont be an kitchen Aid
Jan 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Kenmore 95002 / 95004 Electric Kitchen Range Logo
172 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
