Question about Humminbird Fishfinder 570
My 570 quit showing the depth and continues to show 0.6'. It will show the depth once when first turned on then go back to the 0.6' reading. It worked when I first installed it a couple weeks ago but doesn't seem to work now. Is it the unit or transducer or both? Thanks D.J.
  • 3 Answers
I had the same problem. It was the transducer.
Posted on Aug 30, 2010
I have a 2015 polaris rager that quits now and then and a 520305 code comes up, what is wrong. throttle body has been changed?
I had same problem. Turned out to be temp sensor putting bike into limp mode then quitting. Never seen that code though as my ranger only shows codes from 21-61
Mar 04, 2015 | Polaris 2015 Ranger Crew 570 EPS
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
The unit will not show a depth reading - just shows 0 0?
Try adjusting ur puck,and go into menu look for a shallow,fresh water setting.less than a 100ft put in shallow all other depths in fresh
The unit worked fine for 3-4 months.Now,it just gives a reading of 0 ft. with the water temperature. Once in a while while i'm drifting it will give me a depth for a few seconds and go back to a 0...
It sounds like your transducer has gone bad. You may be able to find a replacement on Craigslist or eBay, since this is an older model. Transducers are pretty sensitive to bumps and drops because of the crystal inside.
Aug 23, 2011 | Humminbird Piranhamax 170
I have a humminbird pmax 170. It does not show depth. It stays on 0 ft all the time. The unit reads temp but no depth
Contact our customer service group and they will be able to help you. There number is 800-633-1468.
Jan 08, 2011 | Humminbird Piranhamax 170
Mastercraft Prostar 197,2005. Electrical problem?
Try your tether , plug and unplug it a few times , sometimes they stick, get corroded from the water..
Aug 22, 2009 | Garden
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Inccorect cartrigde
Try using a pencil eraser to clean the gold contacts on the back of the cartridge. If they get dirty or cruddy, the printer won't be able to 'read' the cartridge correctly.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Feb 04, 2008 | Lexmark X3480 All-In-One Printer
Humminbird Fishfinder 570 Logo
872 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
