Question about Dryers
Kenmore Dryer 697267
I have a Kenmore dryer that was given to me from my mother after my divorce. It has a 220 plug. I do not have a 220 outlet. Can I change the 220 to 110? I took the back panel off where the plug is and the there wires are located right there. What can I do?
  • Anonymous Mar 26, 2014
    i need to see which wire goes to which connection
  • 4 Answers
Most dryers are 220 so they can produce the amount of heat required to properly dry clothes. I would Not recommend trying to convert the dryer to 110 voltage. This may cause you alot of unwanted problems. I would find a Qualified electrician to install a 220 outlet at the location of the dryer .
Posted on Apr 26, 2008
I changed the thermal fuse but my kenmore dryer still wont work what else can i do
Check the door switch.
Check to make sure your are getting 220 volts from your outlet.
Check terminal block for burned wires.
Less common causes: bad timer, bad motor.
May 28, 2014 | Kenmore 63942 Dryer
Can I change the 220 plug on the stackable unit from a 4 prong back to a three prong.
Yes you can. Green in the middle and red and black to the matching sides coming in from above the block where your connecting the cord
May 07, 2012 | Kenmore 98702 Stacked Washer/Dryer
My 70 series dryer the heating element is not working. I checked the heating coil for continuity and it is holding 12 ohms, the fuse has continuity and it has power. Flipped the breaker to se If that was...
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
May 27, 2011 | Kenmore Dryers
My Kenmore electric dryer 697267 will not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
Jun 20, 2010 | Kenmore 73952 Gas Dryer
Kenmore electric dryer 697267... dryer will not start
We read the answer to someone else's question and tried it out... it worked! We replaced the thermal fuse and the thermostat, and everything is running fine now.
Jan 02, 2010 | Kenmore 73952 Gas Dryer
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Hello, I have a Kenmore 80 Series. Washer and Dryer. Bought it from someone on Craigslist. How do I hook them up? Is there a manual any where out there?
Connect your hot and cold water pipes to the washer. Place the drain pipe into a sink or direct drain feed to your sewer system. Plug it into outlet. Dryer - plug it into your 220 line outlet. If the plug is not the same as your outlet you can find instructions on lline with pics on how to change a 3 prong plug to a 4 prong plug and so on...:)
Jun 07, 2009 | Kenmore Dryers
We bought an electric dryer from sears outlet
220 Cords are usually color coded - BLACK, WHITE, RED, GREEN for Ground. Inside the dryer where you connect the wires should be the same colors. Just put the Black with the Black and so on. Make sure the plug is for a dryer and not a stove.
Mar 26, 2009 | Kenmore Dryers
Dryers Logo
220 people viewed this question
Top Dryers Experts
