Question about Acer Aspire 7720-6569 Notebook
Acer aspire 7720-6569 will just lose power center green ring light goes dark and computer must be powered down and restarted. Happen when on web, wking with pictures dnld into computer , or when just sitting there. Sometime must unplug and let sit for half an hour then it will boot up and work for hours or minutes and same thing occurs.
    Problem Solver:
  • 14 Answers
Does it just randomly shut off without warning?
If so, I used to have this problem.. its to with the processor overheating because of the power demand.
The 7720G is a very powerful laptop, so powerful that it can run most games without fail, but they can put a strain on the processor.
My point is, You may be blocking the ventalation system causing the heat to carry on around the machine. The best solution would be is to buy a seperate fan, Like:
http://www.google.co.uk/products/catalog?hl=en&biw=780&bih=485&q=laptop+external+fan&um=1&ie=UTF-8&cid=2019103170749009722&ei=74PqTIP_NpDb4gbS-Yn5Ag&sa=X&oi=product_catalog_result&ct=result&resnum=1&ved=0CCIQ8wIwAA
If this does not fix what I am assuming is your problem, contact Acer Customer Support
Posted on Nov 22, 2010
My acer flat screen monitor will not come on. My mac mini starts up, but the screen stays dark. Last week, it was staying dark after the computer went to sleep; I couldn't "wake it up." After a few...
I will assume that you have checked out the power cables and external cables. If this is the case you will usually notice an indicator light from your monitor. Universally it is yellow or orange when it has power, then turns green when it detects input from your computer. If the Led light doesn't turn green even when your laptop is already booted, your culprits would be your iMac's video controller or your monitor's input cables.
Jan 29, 2018 | Acer AL1715 17" LCD Monitor
Hello sir i have pronble with my acer aspire 4520 when i swicth no the power button the green light on and goes off
If the green light goes on and off that can occur if the the wall outlet is bad you should first try another wall outlet if the problem still exist your power adopter/ charger may have a shortage so you can use another charger that you know is working but must be of the same kind to see if your computer will receive power and if your computer does not receive power then the power supply on your motherboard is bad but it can be replace or change the motherboard
Mar 22, 2010 | Acer Aspire 4520-5582 Notebook
Acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
Dec 19, 2009 | Acer Aspire 4315-2963 Notebook
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
My acer aspire one would not boot it would make it
Did you try to start it with the battery removed from the pc?
Jul 21, 2009 | Acer Aspire One PC Notebook
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Screen goes dark
The problem is with your Switch. Contact Service Center. It is not sounding a big problem.
May 20, 2008 | Acer Aspire 5630 Notebook
Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Nov 09, 2007 | Computers & Internet
Acer Aspire 7720-6569 Notebook Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
