Question about D-Link DI 514 Wireless Router (DI-514)
Loss of signal around the house - D-Link DI 514 Wireless Router (DI-514)
    Sergeant:
    Champion:
  • 301 Answers
Reset the router , press a botton behind the router for a fiew seconds like 20 seconds , turn of the router like 50 seconds and turn on the router and try to connect, if tou do that you loos your personal password , just setting again
Posted on Aug 05, 2010
OVHD when there is rain OVHD does not work
Your television signal becomes weak in the rain because it is satellite based. Even if you don't have a satellite dish, the company that supplies you does. You need to contact them direct. Or, if you do have a satellite dish, you need to upgrade to either a larger one, or if you are on analogue, you need to upgrade to digital.
Apr 28, 2018 | Cars & Trucks
I've lost all programmes except BBC on my TV and retuning makes no difference. The other 3 TVs in the house are all functioning normally
I expect there is a tv aerial signal problem as depending on your area, bbc and itv use different frequencies and signal loss could be the problem.
Apr 15, 2011 | Televison & Video
How to replace the thermostat in a 03 lancer
Hello, follow the upper radiator hose to the thermostat housing, position a pan under the car to catch loss coolant. Remove the the housing screws move the housing out the way and remove the thermostat. Before installing the new thermostat clean around the housing very carefully. Install new thermostat, gasket-if needed, and thermostat housing tightn screws, add coolant.
Jan 05, 2010 | 2003 Mitsubishi Galant
P1613 fault code & engine will not rev over 3000 rpm when you get to 3000rpm it then fluctutated between 2500 rpm & 3000 rpm causing the car to buckaroo
Crank sensor or engine speed sensor is faulty.
Fault:
Irregular power loss on accelerating
The speed of the engine is limited till 2500rpm
Frequent loss of crankshaft position sensor signal
Cause:
It is caused due to leaking from thermostat housing into crankshaft position sensor harness multi-plug
Remedy:
Check and clean the crankshaft position sensor harness multi-plug contacts. Rectify the engine coolant leak from the thermostat housing if found. Take a note of the engine coolant level and monitor it for changes, showing a leak is indeed occurring.
Oct 24, 2009 | 2005 Peugeot 405
If my pc has a strong internet signal - why can't I go online?
its a wireless signal may have to move it around to get your signal things such as walls ,appliances distance can cause signal loss
May 18, 2017 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
MENU PICTURE ON TV BUT NO CHANNELS
This is a problem with weak signal strength, You will need to find a better place to put your television so it can receive enough signal to operate correctly. If this does not solve the problem, you will need to check the satellite box for problems with receiving the signal from the satellite. You may need help from the satellite company to check the signal strength output and input levels to make sure its working properly. I hope this information helps you solve you problem with the loss of satellite signal in your television. Thank you for using FixYa and have a nice day!
Jun 18, 2009 | RCA DIRECTV Satellite Remote Control
Help! How to get the best TV reception in this part of my house!
the area where you live creates reflexions or gaps in the signal (seeing how hard is to get the signal) maybe mountains around maybe big constructions or just simple a deep in the overall terrain. In all this cases maybe the solution is to get signal from the sky. This is done by: ex (dishnetwork, comcast) or any of those vendors with the little round antenna that you pay monthly. Now if the problem is only in that room of the house; then an xtra instalation can feed signal to that area from the other areas in the house where the signal is working good with you other tvs around the house. Just a couple of splitters and good isolated cable is needed to transport it.
Apr 14, 2009 | Televison & Video
Brake lights in rear will not work
Do you have a trailer plug? Look for corrosion around taillight plug under truck in the back, PULL IT APART to see if there is any corrosion. If you find none, than take the taillight housing out and run a external wire from a clean spot on frame to the ground on housing, it could be a ground issue. Did you test light the break light switch power in power out?
Apr 10, 2009 | 1991 Chevrolet C1500
D-Link DI 514 Wireless Router (DI-514) Logo
43 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
