Question about Dell Computers & Internet
It takes 5 minutes for my computer to boot up. It's a 7-yr old Dell with XP. Also, I've been getting a message "Virtual Memory Minimum too Low". What can I do to fix it or should I buy a new computer?
  • 748 Answers
After seven years Windows tends to accumulate lots of "trash" in the system, especially if you installed a lot of programs over the years.
First step I would suggest is to try a good disk defragmentation software. You can download and install a trial version of PerfectDisk, or a completely free Auslogics application: http://www.auslogics.com/en/software/disk-defrag/
Run it several times and see if it makes things better. If the improvement is not enough, a good move would be to get someone experienced to save your personal files somewhere safe (a USB disk for example), then format (wipe) the disk completely and reinstall Windows from scratch + all the updates + the software you really use.
Seven years can be a lot, if you are after power-hungry modern applications and games. However, if you just want to use it for simple stuff, it can be quite enough. You don't provide the specs, but a simple RAM upgrade may just do the trick of making the machine comfortable enough to use.
Posted on Aug 05, 2010
    Sergeant:
    Champion:
  • 301 Answers
Hi , no do not, just format and reinstall windows, remember that its better to have a new computer for the new ciberthings , but you can use the old to
My computer runs slow. It takes a long time to boot up. Occasionally I get a message that virtual memory is low. Is there something I can do myself?
Hello
Yes, this is a very common problem for computers which does not have the sufficient amount of ram installed for the software the machine runs.
At the link below you will be able to read a couple of tips on how to improve your computer speed.
Click HERE.
Kind regards
Andrea
Sep 19, 2010 | Dell Microsoft Windows XP Home Edition
I get a message low memory how can i fix this dell inspiron 1525
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
Jul 21, 2010 | Dell Inspiron 1525 Notebook
I have just reinstalled Windows XP Professional after having failed to get the PCI 0404 to work properly with Windows 7. However now with the latest drivers and DSP program on reboot or computer boot the...
Please try to check if you have met the minimum requirements for Windows 7, check your memory if its enough for windows 7 and also your hard disk. And after installing back to XP you still encounter this problems try checking your memory again, detach it from the board and try cleaning it then insert back again.
Jun 11, 2010 | E-Mu 0404 Bundle Sound Card
After inserting CD - get the message:
run a defrag and a disk cleanup that should do it :)
Apr 13, 2009 | Scholastic I Spy School Days for Windows,...
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Virtual Memory Minimum Too Low
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Dec 21, 2008 | Microsoft Windows XP Professional With...
I get "virtual memory low" message and cannot boot.
The real solution to this is going to involve spending some money to buy some new memory. It should cost about $30-50 depending on type and amount. 256Mb is not enough for Windows and other software to run. I would recommend buying at least 512Mb additional to add. Before you purchase open up your machine and look to see how many memory slots you have and how many are currently used. According to some specs on the internet, here is what you have.
Maximum Memory 2GB Memory Slots 2 (1 bank of 2) Install in pairs non-removable base memory 0MB Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds. Please check the speed on the memory modules currently installed, or use our "Check Your Computer" to find the correct module.
It is simple enough most anyone can do this themselves, and I could walk you thru it, otherwise you would need to take it somewhere, but my recommendation would be to do it yourself and simply ask me or others here for advice. Let me know if you want help to do this.
Good Luck!
b
Dec 13, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
93 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
