Question about Konica Minolta magicolor 5550 Laser Printer
Bizhub 40p printer stops working with a fatal error: SERVICE CALL0300 POLYGON MOT What do I need to fix this problem?
SDtester
  • 41 Answers
SOURCE: Fatal printer error
1. First open the top of the unit remove the ink tanks and set them aside.
2. Remove the printhead and then unplug the printer. re-insert the printhead back into the printer. Remove it again and re-insert it. Do this 3-5 times. If you need help doing this, there are instructions on installing a printhead in the electronic manual PDF file provided by Kodak. (What this removal and re-install is doing is scraping of anything that might be disrupting the contact between the printhead and the printer)
3. Now install the printhead and install the ink tanks.
4. Plug in the printer want for it to bootup.
5. If the error comes up again you need to contact to Kodak about getting a new printhead or Return your printer and exchange if for a new one.
Also do be sure to update your software and printer firmware through the Kodak site or through the software provided. These printers print nice photos and the ink is cheep. Dont let this road bump turn you away from them.
Kodak and or I am not responsible for any data loss or any damage to any equipment that occurs as a direct or indirect result of following the procedures described above.
Posted on Feb 25, 2008
SOURCE: Konica magiclolor 2530 DL Fatal Error 1bh
I have the same problem and I can see that the black "V"shaped piece is loose and sometimes keeps the cover from opening.
I can not see where to put the screw to fix the problem. Any suggestions?
Posted on Sep 21, 2009
  • 110 Answers
SOURCE: laser unit polygon motor failure
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Posted on Oct 22, 2009
  • 9 Answers
SOURCE: Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
A 020 error is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Call Okidata, order a TNY for the C7300, probably bout $130.
Posted on Oct 31, 2009
  • 489 Answers
SOURCE: Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
Posted on Nov 16, 2009
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
"Service call0300 Polygon Mot"
Polygon motor is the motor located inside the print head where the LASER is at the motor is what moves the LASER beam across the drum when placing the image on the drum. SO you might have a bad print head because the motor and LASER come as one. And no you can not replace the motor separately.
Apr 03, 2015 | Konica Minolta Magicolor 5650EN Color...
Service call 0300 polygon mot
Replace the print head which houses the LASER
Feb 01, 2014 | Konica Minolta PagePro 4650EN - Printer -...
THE COPIER DISPLAYS ERROR C4101
C -4101 Polygon motor error.Change the polygon motor,if you can not reset the malfunction code.
Mar 02, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c4101
this is a polygon mirror motor failure replace the laser unit. to reset the error code open then close the front door while the machine is turned on if the error code comes back the parts will probably have to be replaced
Oct 25, 2012 | Konica Minolta Bizhub 362 Copier
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
C4154 Trouble code... what is it?
C4154 means that the Black Polygon Mirror Motor is not rotating or spinning as it should.
You can try turning the machine off and on to reset the code and see if it comes back. If so then you will need a service tech to come out and service it. The Polygon Mirrir Motor is a spinning mirror that the laser is bounced off of and is used to write the image to the drum unit.
Here is the info direct from the service manual:
C4154:The polygon motor fails to turn stably even
after the lapse of a given period of time after
activating the polygon motor.
• Motor lock signal detects HIGH for a given
period time consecutively during the polygon
motor is rotating
Good Luck and Thank You for using Fixya.
Feb 02, 2011 | Konica Minolta Bizhub c203 Copier
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
My Sharpe Al-1553 keeps flashing L and won't work
This is a fatal error with the scanner. It is most likely to be a power supply or positioning error with the scanner not having returned to the home position or the positining sensor. You will need a service engineer call to rectify this.
Sep 24, 2009 | Sharp AR-M205 Copier
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 5550 Laser Printer Logo
691 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
