Question about Olympus FE-230 Digital Camera
My Olympus Fe-230 camera's lens won't open. I turn the camera on and it makes the sound of the lens opening, and the lens begin to "push out" but then retract. This happens a few times and then the camera stops "trying" to open. The actual lens is never exposed [as in the black 'cover' never opens]. How do I fix it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
  • kakima Oct 07, 2012
    You don't need any special software.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
SOURCE: olympus FE-230
Same with mine. I'm going to bring it to a camer repair shop.
Posted on Jan 12, 2008
Agent Allan
  • 480 Answers
SOURCE: Olympus FE-210 lens does not come out
Hey memiche,
You could try resetting the camera to the default factory settings, and directions on how to do this are on page 20 of your camera manual. If this doesn't work then there is either something obstructing the movement of the lens (i.e. sand), or damage to the lens mechanism. If it is something obstructing the movement of the lens you could try blowing compressed air into the side of the lens to try and dislodge whatever is in there. If that doesn't fix the problem you could try putting the camera on a flat surface with the lens pointing up and holding in the shutter button, and while doing that turn the camera on. If none of this works I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 02, 2008
SOURCE: Camera malfunction
when the lens are protracting i held them  and they didnt go back in. then i turned it on and it worked! but the lens dont go back in when the camera turns off and the zooming is messed up because of it, but it works!
Posted on Feb 08, 2009
Jus ask me
  • 120 Answers
SOURCE: I have lost my fe-230 CD
HI
go to this link and download the software
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1283
http://www.bioticaindia.com/fe-230.html
Posted on Feb 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Olmpus fe-360 wont turn on. The lens won't
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
Posted on Nov 23, 2009
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
No power on olympus fe-230
check battery contacts, and while door is open, power on and push the battery to see if anything happens
Apr 01, 2009 | Olympus FE-230 Digital Camera
We have an Olympus FE-230. When the camera is
It's possible this is a repair issue with the LCD screen of the camera especially if you are able to review previous images but cannot take any new images. You may want to call Customer Service to discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 06, 2009 | Olympus FE-230 Digital Camera
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
FE-230 Failure to come on
Hi Gary
Is the camera under warranty and registered with Olympus? If not registered, make sure you do that online first. It also extends your warranty to 13 months. If no receipt, It was a gift.
You most likely have a bad lens assembly (was it dropped?) or microprocessor. Here's your link...
Olympususamerica.com
Consumer division, customer service 1-800-622-6372 M-F 8 to 7 EST
Outstanding people to deal with
Hope I could be of some help. Regards, Paul
Aug 16, 2008 | Olympus FE-230 Digital Camera
Lens not opening
If your battery is fully charged, then it would need to go to repair
Aug 04, 2008 | Olympus FE-230 Digital Camera
Fe 230 problem
try olympus repair for about $80.00
Jul 14, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230
Dec 16, 2007 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Logo
170 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
