Question about LG Televison & Video
Tv sometimes will not shut off. have to unplug it then plug it back in to correct problem. occurs periodically.
  • 4,102 Answers
Hi, could you please tell me if the problem is when you are pressing the off button on the telly or is it when you press standby on the remote or does it happen with both.
also do you mean it wont go onto standby when just the red light is on or do you mean switch it off completely
please let me know then i can assist you further ok
Posted on Aug 05, 2010
  • 2 more comments
  • frankstefani Aug 05, 2010
    both button on television and remote will not turn off television. unplugging it acts as a reset mechanism.
    both button on television and remote will not off television. unplugging it acts as a reset mechanism.
  • paul proctor Aug 05, 2010
    hi do the rest of the buttons on the control work?
    no.only after I unplug it and plug it back in.
My tv just shuts off
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time
Dec 29, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sanyo tv suddenly shut off
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
Nov 30, 2011 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Turned off television after watching it this a.m. will not turn back on. changed batteries in remote. red light on front of tv is not on as usual when the tv is off.
Hi - Check to see that the power cord is still connected or that the power source has not been shut off.
If it is plugged in, if the power strip is still on and working correctly, and if the breaker the tv is on is not tripped, then I would recommend unplugging the TV for 5 minutes and plugging it back in. Sometimes the tube in the TV can become "overloaded" and needs a brief 'cooling period'. Let us know if this does not work. Thanks!
Feb 28, 2011 | Apex Digital AT2702 27" TV
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
Tv just goes blank shoots off then i have to turn it back o n
Using the menu/options button, check whether there is a sleep timer. You may have accidentally set it, and it will shut off the tv at either a particular time, or after a period of time has elapsed.
Jun 30, 2009 | RCA Universal Remote Control
Tv shuts off tv/video doesnt work
that is a indication that a fault is about to occur, dont force that tv take it to a technician before it switches off completely, a power supply is supposed to be checked.
Mar 26, 2009 | Panasonic CT-36SL13 32" TV
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
55HX70
needs convergence ics period
Nov 24, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
18 people viewed this question
