Question about Video Game Consoles & Games
Needadis for my throttle for thew pro yoke - Video Game Consoles & Games
  • 53 Answers
Mmmmmmmm
Posted on Apr 26, 2008
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
I have just bought a Pro Flight yoke and throttle system it has a computer cd with it my question is this...Do you put in the disc just before loading up the yoke and throttle system??
How to Set Up a Saitek Proflight Yoke System Instructions
    Mounting the Yoke
Mounting the Yoke
  1. Determine where you will set it up. You need a desk or table with a wide, flat surface. Clear away objects on the desk that might be in the way or that could be accidentally knocked off. The yoke must be mounted on top of the table and takes up a good deal of space, but the throttle may be mounted in front of or even under under the table if you prefer.
  2. Remove both units from the box carefully. The system is lightweight, but care should be taken not to drop it. Note that there are also some loose parts in the box including the large clamp which attaches the yoke and a smaller clamp for the throttle unit. Note that there are some instructions and diagrams on the back of the box that may be of use.
  3. Place the yoke on the surface and position it where you want it.
  4. Pick up the yoke clamp assembly and make sure that the threaded plastic bolt is inserted, but not screwed in. The clamp fits underneath the table with the two upper prongs sliding into the corresponding holes on the front of the unit.
  5. Adjust the yoke and clamp as needed to insure it is in the exact position you want. Then tighten the plastic bolt. Test the yoke to make sure it is stable and does not move on the table when you manipulate the controls.
  6. Pick up the throttle unit and its clamp assembly. Unlike with the yoke, the clamp assembly must be screwed into the back of the throttle unit using small screws. Note that it may be attached in two different directions depending upon how you wish to mount the throttle to your table (either above or in front of it). Decide now which way will work best for you. See the images on the box for reference.
  7. Position the throttle clamp around the table surface and tighten the plastic bolt, just as you did for the yoke.
  8. Connecting it to Your Computer
  9. Look at the back of the yoke. There is a single USB cable which is permanently attached to the yoke. Plug this cable directly into a USB port on your PC. The ports on the rear of a computer usually work better for this purpose than those on the front.
  10. Look at the back of the throttle unit. There should be a single cord coming out the back of it. Note that it is not a USB cable. Instead it has a round connector, like those used on non-USB keyboards and mice. Plug this cable into the round port on the back of the yoke.
  11. Turn your computer on. It should recognize the yoke as a new plug and play device. Note that the computer will see the yoke and throttle as a single device rather than as two separate ones. The included software is not required. The yoke should work as soon as it is plugged in.
  12. Go to website http://saitek.com/uk/down/drivers.php to download and install the latest drivers.
  13. Assign buttons and commands directly through your favorite flight simulator.
  14. Additional peripherals such as rudder pedals or another throttle unit may be added using the USB port on the back of the yoke.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Dec 14, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
Hi there I plug flight yoke into usb and get no recognition and no power even the green led on yoke does not light?? however if i plug the throttles in the light does come on on the throttle assy (small...
have you tried hook this flight yoke to another computer, to see if it does the same thing. if you have a extended the usb cable this can couse an issue sometime. please explane more on the problem
May 14, 2010 | Saitek Pro Flight Yoke System Flight...
The yoke has effectively got a USB hub built in, and it sounds like your throttles are getting power from the hub okay, but the yoke is not. Suggest you return it for a replacement to Saitek
Mar 26, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
Hi, I contacted Saitek approximately 2weeks ago regarding the blueand purple backlight failure on my Eclipse II keyboard. I am awaiting your reply. I now have, what I feel to be a more serious failure on...
Hi Chris
Ensure that you have the usb lead from the yoke plugged into the rear of the PC as these give the most current. Ensure the drivers for the yoke are installed properly and they are the latest for your operating system. If this still does not work, then the yoke is faulty. Good luck!
Jul 23, 2009 | Saitek Pro Flight Yoke System Flight...
Where i can find it?????
I have bought 2 sets of Saitek proflight controls ( Yoke & trottle quadran) for AUD$ 399 each.
I only need one yoke but 2 Throttles. happy to sell the second yoke ( New still in the orriginal packaging with warranty & receits -purchased yeasterday 28.1.2009) for AUD $250 + postage.
charles_loko@hotmail.com
+61 0421 035 975
Jan 13, 2009 | Saitek Pro Flight Yoke System Flight...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
