Question about HP Wireless Optical Mouse
I've only had it a month and it stopped working all of a sudden. I changed the batteries but that didn't fix it? The red light on the mouse is on but the green light on the USB isn't blinking?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
If it is usb base you need to press a connect button on the base and the mouse to connect the two together.
Posted on Aug 05, 2010
  • KT103 Dec 19, 2010
    Yes it was quite helpful and so easy too. I'm almost embarrassed...but then just almost...lol.. Thanks a mil
5 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Dell wireless mouse is blinking red, but functions. Problem?
try to rest the connection by pressing the connect button on the reciever and under the mouse together and relaesing them. it should work
Posted on Jan 22, 2008
cpenzes
  • 1102 Answers
SOURCE: my USB plug in for my GE wireless optical mini mouse
There should be a button on the usb itself.You can try removing it plugging it back in then push that button if still red then you can try changing the batteries.
Posted on Jan 12, 2009
SOURCE: intermittent problem: green usb and red light on mouse blink
Check that your mouse pad isn't glossy or contains red colors
Posted on Aug 09, 2009
SOURCE: Microsoft Wireless 4000 Mouse - No Red Light on Base
The red laser light stopped working on mine and it turned out to be the connetion between the battery tray and the circuit board. There is a metal tab on the circuit board and a matching one on the battery tray. When the battery tray slides in correctly the two tabs touch and viola (!), my red laser light came back on. Maybe one tab or the other got bent when I slammed the tray in crooked when replacing a battery- who knows.
Posted on Dec 05, 2009
Logitech M510 suddenly stopped working
What does the device manager say about the hardware?
It could be loss of the usb device controller. Windows XP is old and that is an indication that the hardware is old too.
Mar 25, 2017 | Logitech M510 Wireless Laser Mouse
I bought a microsoft arc mouse, wireless, with a USB transmitter, just a month ago and it was working perfectly, then suddenly and i mean SUDDENLY, stopped working, no reason it just happened, the light...
Hello, have you tried changing the batteries in your mouse? They are probably dead or dying and that is why it is not working. Also, try restarting the computer. If you cannot even use a regular wired usb mouse, there may be something going on. Try changing the batteries, restarting the computer, and using a regular usb and a regular PS/2 mouse.
Thanks for using FixYa!
Jul 24, 2011 | Microsoft ARC Mouse
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
MU203 mouse not working
Replace the batteries and try this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 12, 2008 | ViewSonic MU203 Optical Travel Mouse
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Cordless mouse suddenly stopped working
I have had the laser fail in some of these mouse's. I have also had the batteries fail. I have seen cracked circuit boards from the mouse being dropped.
You mentioned that you changed the batteries. I am assuming that you tried new batteries that you know are good.
Technicaly, there are no servicable parts inside of these mice. If the fault is something very simple it can usualy be serviced.
Jerry G.
Feb 20, 2008 | Logitech Cordless Mouse
Wireless mouse is not working
ya..there is a small button on back side of the receiver..plug the receiver to the USB port and press the button for few secs and red light will start blinking..then a similar button is there for the mouse below it..press it and it will work fine.
Sep 26, 2007 | Dell Wireless Keyboard Optical Mouse w0147
HP Wireless Optical Mouse Logo
820 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
