Question about Whirlpool Duet GHW9150P Front Load Washer
When trying to run the washer we get a SUD error almost right away. Than after a while of nothing happening a F 35 error pops up.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
I keep getting error codes on washer and will not continue the cycle
That code in most cases means you have a bad pressure switch. It is generally $99.00 (approx) for the cost of the part.
May 11, 2012 | Maytag Performance MHWE500V Front Load...
I keep getting either SUDS or the F35 code. I finally was able to get it to run so I ran it without detergent. Now I tried it again and it is back to SUDS again. Any ideas?
ok...run unit on rinse and spin only,,we need cold water,,if unit still shows sud error make sure drain hose is not kinked,,,if we still have a sud condiction or error ,,remove toe panel and clean filter.good luck
Sep 07, 2011 | Kenmore Elite HE5t Washer
Hello! I have a Whirlpool Duet Seam Washer #WFW9600TA that after 3 years has started with the SUD and F 35 error codes. I have been studying FixYa and have discovered this has to do with an Analog...
W10156252 - Nope, just put it in, and away you go. :)
When you pop the pot off of your machine, it is a small brownish box, about 1x3 with a black hose coming out of the bottom. It is located on the right panel towards the rear
May 17, 2011 | Washing Machines
I keep getting "Sud", "F 35" errors when trying to run washer... please help!
you are using too much soap-are you using he detergent-turn it off drain and rinse-after you do laundry-clean washer with bleach only
Oct 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashes sud then F 35 and locks up, tried running it in the rinse cycle but it continues to do the error code.
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Aug 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wfw9500tw01 model suds and then f-35
Thank you !!
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When we try to start Washing machine (Kenmore Front Loader) A code F 35 or Sud pops up And flashes.
Apparently this problem "Suds" and "F35" error codes is happening to a lot of people ~ If you do not have any clogged hoses, then the Analog Pressure Switch is more than likely the issue.
Here's the downside, the problem is so wide spread that the part is back ordered for weeks. You would think that SEARS Extended Warranty Service would keep this part in stock so their customers are not without a brand new washer for over a month!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
