Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printing Problems Suddenly, my HP inkjet is stuck in some bizarre cycle. Here it is: #1 It instructs me to put in plain paper & push OK so it can align the page #2 I put in paper push ok #3 The paper starts to go through, stops, and I get the message "paper jam" (I was clearing it, but discovered I only have to push "OK" and the machine will push the paper unharmed #4 The message on the printer says to put in another piece of paper so it can align. However, I don't have to push the OK button -- It automaticlly takes in another piece of paper #5 But it stops halfway, says "Cancelling allignment," and keeps the cycle going. The same thing happens when printing a page. But at this point, I can't get it off "allignment." Any ideas? Judi
  • JudiG May 27, 2008
    Thanks for the suggestion, but I'm not clear on your directions. When you write "press & hold # 3," what "#3" were you referring to? The actual number on the keyboard? Or the F3 button? Or the number 3 on the right-hand side of the keyboard, the one that also says "pg dn?" None of those options work. (And believe me, I tried).
    Is there a number on the all-in-one printer that I'm not aware of?
    Or did you mean one of the other buttons, such as "setup?"
    Judi
  • JudiG May 30, 2008
    I didn't understand the instructions. I posted a question, trying to clarify it, but so far haven't received an answer.
  • 40 Answers
Turn machine on..
The unplug power cable on the back....
Press & Hold # 3 while connecting power cord.
keep it pressed & hold till screen display reset or shuts down...
Then follow the prompts on screen...
If this will not resolve the issue , then replace
call 1800 474 6836 & request them upgrade , You will save some money on purchasing new.
Posted on May 27, 2008
The orange light keeps flickering. I checked to see if any paper is stuck but couldn't see anything. There's something preventing the printing process. What could it be? Need help. Thanks
hello
which one of these HP p/n's is your fax ? C4647A or C4649A
is this your fax ?
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649A
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649Apic00602.gif
go to this link , follow instructions, -- HW TO CLEAR PAPER JAM
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu50320&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=60718
please rate my service
Nov 05, 2010 | HP 920 Plain Paper Fax
Can't select "Plain Paper" when printing from Excel (2008) on a Mac OS 10.6.2. From the Print dialog box, I select "Paper Type/Quality" and attempt to change the "Paper Type:" from "HP Premium Plus Photo"...
Hello, Jon.
There are some problems reported with the printer driver from the HP site, in case you obtained your drivers, there.
Go to the Apple website to obtain the driver and reinstall the driver.
Hope this helps.
Jan 09, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
Nov 06, 2009 | HP DeskJet 920c InkJet Printer
Black ink not working
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Jan 14, 2008 | HP LaserJet 2420 Printer
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
