Question about LG 42PC1DA 42 in. Plasma HDTV
I have an LG 42PC1DA. We were watching TV and it popped- the picture went but there is still sound. I have read through a few different posts on here and they have conflicting advice. I don't want to buy a part and it not work.. Please can you help? Many thanks :)
  • LG Master
  • 11,800 Answers
A popping sound is a clear indication that one of the electrolytic capacitors has failed the big way. You were lucky it didn't fried anything else. Just open the tv find and replace the failed capacitor. Soldering is required so if you haven't done this before then its time to call someone who has.
Posted on Aug 05, 2010
I have a Plasma TV LG model # 42PC1DA. We have perfect sound, but no picture. Tried the contrast, tried unplugging for 30 min. What could be the problem and how much might it cost to fix it?
Did you tried diferent sources from where you get the image? For example you could try to connect a video camera, laptop, dvd or any other thing you could hook it up in your TV and check if there is still no picture.
If the screen is burned it costs the same or a bit less than a new one
Good luck
May 06, 2011 | LG 42PC1DA 42 in. Plasma HDTV
I have an LG 42PC1DA and there is no screen but there is sound. Sounds like the capacitor failed from reading solution posts. I was wondering what i should expect to pay to have it fixed by someone else?
Shop rate will be $200 and up plus parts.
Yes, it can be caps failures in power supply, Z-SUSTAIN, Y-SUSTAIN boards, you also need to check the fuses on all those 3 boards, they are common failure boards.
See the pictures of the boards here:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LG+42PC1DA&stock=all
Please leave rating if it helps.
Jan 29, 2011 | LG 42PC1DA 42 in. Plasma HDTV
We bought an LG 42'' plasma T.V. 42pcida-ec from dixons 2006 £1500. the other night heard a popping sound and the picture went off but the sound stayed on. LG wanted nothing to do with it and were no...
That pop was a "cap" capacitor blowing, open up the TV and look for a burn mark. And of course LG isn't going to fix or supply info for free to fix this for free, that is just good business, I would agree with them..
Jul 21, 2017 | LG 42PC1DA 42 in. Plasma HDTV
Lg Plasma PC1DA no Picture??????
The provided description is typical for failure of a YSUS board, which is in turn quite typical for LG 42PC1DA and a bunch of other makes and models which all share the same internals.
To find out whether it's the YSUS or the ZSUS board that has gone bad look at the following article:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
This is for a different make and model, but has the same core modules that 42PC1DA has.
This article also addresses the case when the TV refuses to come on, which is usually caused by a shorted IPM module on a YSUS board which, however, did not lead to burning the fuse as it normally does.
The failure is actually the same, only the symptom is different.
If the failed board is the YSUS (which is the case most of the times, but not always) then you may want to check
http://blog.coppelltvrepair.com/2011/03/how-to-uninstall-6871qyh053b-and.html
Finally, you may consider the following:
http://blog.coppelltvrepair.com/2011/05/should-i-replace-repair-one-or-both.html
Should you need to have one or both boards serviced you can use the following:
http://www.ebay.com/itm/Sustain-6871QYH053B-LG-42PC1DA-REPAIR-EXCHANGE-/110535815308
Apr 12, 2010 | LG 42PC3D 42 in. Plasma Television
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
My 42PC1DA is just under 3 years. It has been
Normally, it causes by failure of power supply board.
Aug 18, 2009 | LG 42PG20 42 in. Plasma HDTV
Pop no picture
i think the power supply went out .not cheap, parts and labor about 450
Jul 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Plasma tv
Hello
Check the contrast settings
If you are a Technician than just check the video supply from 150 to 200 volts at all three RGB Cathodes in most of cases there would be dry soldering in others it could be due to failure of supply resistance check base biasing voltages if u can provide more information then I could pin point the fault
Good Luck
Nov 16, 2007 | LG 42PC1DA 42 in. Plasma HDTV
LG 42PC1DA 42 in. Plasma HDTV Logo
524 people viewed this question
