Question about Honda Pressure Washer PSI 3000
Engine will not start,almost sounds like it is backfireing out of the carburater ,I cleaned out the old gass and put new in, cleaned gas lines,blew out carb with air two times, it ran for about 10 seconds the first time, and nothing the second time,----------What !
  • 21 Answers
Pour a large amount of carb cleaner into the gas tank
With choke on full, pull cord often to work carb cleaner into carb and then let it sit for a day or four.
Your carb is dirty for sure.
The venturi and jets are so small on these carbs that they are easily clogged with gunk from old gas
Posted on Aug 29, 2010
Yamaha Grizzly 600 backfires and doesn't want to idle
Did you line up the stator plate line with the notch on the cases? Sounds like your ignition timing is set a bit retarded. I would pull the side cover off and check the timing marks.
Sep 27, 2016 | Yamaha Motorcycles
Why won't it start?
sounds like the fly wheel key might be partly sheared , putting it out of time .
Oct 31, 2015 | Husqvarna HU700FH 22-in Self-Propelled...
Cant start 94 cadillac elderado
Check fuel pump pressure and fuel pump regulator. It sounds like you are not getting fuel into the system and if you are you are not getting enough fuel into the system
Jan 02, 2010 | 1994 Cadillac Eldorado
Still not getting the gass
Remove the float bowl and spray out the needle and seat this should clear it out, you will know if it is cleared out when the gas flows out of the needle and seat, be careful not to bend or be rough with the float, if the gas line has a petcock or shut off valve on it ensure that gas flows through the line by removing the line at the carb and see if gas is reaching the carb if so then the needle and seat is gummed up.
Nov 06, 2009 | Garden
My atv won't start after a tune up
you carburater is plugged internally, time for a rebuild or a new one
Oct 26, 2009 | 1986 Yamaha RD 350
2003 honda crf230f will not start.bike worked fine last fall.i put a new spark plug in it,cleaned the carburater,cleaned the air filter & changed the oil.it seems to have good spark but just keeps cranking...
IF you have a battery get a new one ; put in new gas ; super; dsid you ajest any screws on carb. You tight need to run a prime tank right to your carb to prime it; and then hook your tank backup new gas lines to your carb. Now break out with the WD40 to spray all switches for rust.
Mar 23, 2009 | 2003 Honda CRF 230 F
Misfire and backfire at low rpm, runs rough at low rpm
You did not say whether or not this was a carburater engine but from the sound of it one of your jets may be sticking, a good cleaning of the jets will most likely fix the problem, the likely cause is a small build up or piece of debris on the jet.
Jan 01, 2009 | 2003 Triumph Speedmaster
I have a 1981 Toyota 4WD with a 22r engine. Truck has been sitting up for about 8mos. I purchased it and got it home. The only way I can start if is by pouring gas in carb. I have replaced all vac lines...
check the fuel pump, maybe it is not working. if you put a new accelerator pump, I wonder if it's same as the fuel pump. if so, maybe you need to rebuild your carb, clean the small fuel line in the carb, something block there.
Jul 27, 2008 | Toyota Pickup Cars & Trucks
Honda Pressure Washer PSI 3000 Logo
320 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
