Question about Bose Wave music system Multi-CD Changer 3-Disc
Bose Multi 3 Disc Changer - CDs stick, won't eject, makes noise as if it is self destructing. I am afraid to turn it on for fear it will damage the unit.
  • 532 Answers
Hi
Same thing happened to me and I called Bose.
They asked me to unplug everything (including unplugging the changer from the radio and the changer from the wall), waiting 2 minutes or more, and then plugging it back together.
If the CD doesn't eject after that, they want you to send it in for repair (flat $75 charge + tax & shipping).
Thanks.
Posted on Aug 05, 2010
  • sclay607 Aug 05, 2010
    Thanks, I will do that.
    Appreciate your help.
Boss assembly three disk "stacker" won't eject CDs
Someone is going to have to open it up and LOOK to see if jammed, out of alignment or has damaged mechanism. Any of these can prevent the unit from working.
Dec 15, 2012 | Bose Wave music system Multi-CD Changer...
How do I load cd into bose multi changer
The owners manual should tell you that- I think you just insert them.
Dec 08, 2012 | Bose Wave music system Multi-CD Changer...
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Multi cd bose player will not eject 4th cd.
OK, this problem is everywhere with the bose cd changer addon. Many people can still play a cd with the top one fine, but cannot get cds to eject and/or read in 3 disc changer. My friends mom had one and after finally hearing back from bose, they said send it in with $100 to get fixed. If you have to send in and you value your cds, you may want to open it up and get them out. Use this at your own risk, there are no warranty stickers I saw and there will be exposed voltage, shock hazards, etc.; so if any of this worries you, stop here. By proceeding, you are admitting that you are capable of minor repairs and therefore I'm not responsible for any damage or harm caused. OK, here it is:
Unplug everything. On the bottom of the cd changer unit are 4 screws (silver ones recessed about 3/4" or so, use phillips screwdriver) to remove. Turn unit upright again and lift cover slowly straight up. In the front of the unit is a ribbon cable you will want to disconnect that goes to the cd 2-4 lights. Take note which side the dark blue tab is on and gently pull out by dark blue tab, rocking side to side if needed) You can then pull cover all the way off and set aside. Plug power into back of cd changer (careful not to touch anything inside) and see if the cds want to eject now. If not let the initializing process finish and repeat. This time see if you can gently help the cd out. The problem may also be the spindle not lowering, you can look for this movement during the last step of init. process. Work your way fom the top tray down removing the cds gently, remember we open it up because they were valuable to us, don't destroy them now, and don't ever use anything that could possibly scratch either top or bottom of the cd, use edges instead. Start to replace cover making sure to reattach ribbon cable back into socket the same way it came out. do not force too hard or you may crease and break ribbon. Gently replace cover and grab both top and bottom to turn over. Replace 4 phillips screws making sure not to overtighten or cross-thread. Now you may return to bose or just find an independent repair shop in your area, they are usually quicker, more polite, usually cheaper, and best of all, local!
Dec 15, 2007 | Bose Wave music system Multi-CD Changer...
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Bose Wave music system Multi-CD Changer 3-Disc Logo
405 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
