Question about LG Microwave Ovens
Sir, My microwave model is MG-2341BR.It is a touch screen model.I usually pre -cook the vegetables in auto cook mode,for which we have to choose the weight of the vegetables.After pressing the weight only it starts functioning.But even though Iam pressing the both (more or less) it is not showing the weights and the auto cooking work is not done.The other functions of the unit are ok.Kindly help me in this regard. Sincerely, Suhasini
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Posted on Dec 11, 2006
  • 4 Answers
SOURCE: Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Posted on Nov 23, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
Posted on Nov 29, 2009
  • 534 Answers
SOURCE: Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Posted on Mar 31, 2010
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Last year i bought microwave model no:black & decker from dubai. but my family members does not know to use all touch buttons. once my daughter tried to prepare fry some vegetable...
It is important that you attend a class on microwave cooking as it is important that during the process of microwave cooking it is the conduction in the food -- the molecules are agitated with microwave energy to heat up individually as the vessel does not heat.-
So the TIME and the POWER SET ON THE MICROWAVE is very critical which must be learned.
Start by keeping a glass/cup of water and choosing 1 minute for warming . Now watch and advance the time as you notice the heat building up.
Dec 23, 2010 | Microwave Ovens
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Microwave won't heat up while in use
It sounds like the unit is in demo mode, they usually have a small d on the screen, try holding the "kitchen timer" pad down for 5 seconds, it should then work, if that doesnt apply to your model look in the trouble shooting guide of your owners manual, it will explain how to deactivate "demo" mode there...Phil
May 18, 2009 | Kenmore 63252 Microwave Oven
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
Not heating up
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Mar 03, 2008 | Emerson MW8985W Microwave Oven
Microwave Turns on automatically
I would remove the plug from the mains for at least one hour. This should remove any memory
Jul 04, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
