Question about Car Audio & Video
Kia carens 2007 radio removal ? - Car Audio & Video
motor1258
  • 6674 Answers
SOURCE: not holding on slopes
Take a look underneath for cable running to each rear wheel & then come together at one cable going forward. Adjustment should be in that "Y" area.
Posted on May 10, 2009
  • 68 Answers
SOURCE: how to replace radio in 2007 kia optima
The trim snaps in, no screws! I have used a hook type screwdriver, the kind used to install springs... I carefully insert the tool between the lower left corner of the radio and the bezel. Rotate the tool 90 degrees toward the bezel and pull straight out. Id say it comes off with maybe 15 pounds of pulling force. The radio is screwed in with brackets. You'll see once the bezel is off. **Keep in mind that many Optimas use an external amp located between the right rear door and wheel well. Also, some use 2 ohm speakers, all the way around. You may need to change all of it to upgrade your sound system, I did**. Good luck.
Posted on Jan 29, 2010
Magaiver
  • 707 Answers
SOURCE: how to fit a wheel bearing to a kia carens front
It is only a four bolt sistem to change after the brake *** is removed. U may also have to remove the upper and lower control arms.
Posted on Aug 10, 2010
  • 4793 Answers
SOURCE: kia carens 2003. (UK) Don't know alternate name.
take out all the screws in the door handles etc,slide the chrome suround forwards on the interior doorpull and remove.then, very carefully prise off the inner door panel(use a Y tool for the clips,or a wide screwdiver..you will break some) with the window up,you will be able to see a wire hanging down from the outside handle,it is the clip that holds this on that is broken(very common)if the clip is okay then you will have to see what else is needed.but it will be obvious.
Posted on Aug 13, 2010
  • 137 Answers
SOURCE: my problem in my car
once I have a problem similar the mecanic solve it by soldering the air bag cables under the seats, because the plugs having bad conections. its easy and cheap.
Posted on Feb 04, 2011
Engine management light flashing
code refers to "particulate trap" which must be the catalytic convertor put some fuel addative in the fuel tank, get one that specifically states the cat con as well as valves/cylinders etc follow the products directions
Apr 29, 2014 | 2006 Kia Carens 2.0
Kia carens problems
look in the runner for a dropped coin!
Dec 08, 2013 | 2009 Kia Carens 2.0
Is it possible to adjust clutch on a 2007 KIA carens?
Clutch is Hydraulic, there is no adjustment besides free play and you should not adjust that
Oct 20, 2013 | Kia Cars & Trucks
The horn of my KIA CArens has stopped working. I suspect something at the push at the steeing wheel. Any help
check horn fuse
measure voltage at horn
one wire will be earthed to car body hopefully and the other wire will get plus 12 volts when the horn is pressed.
or one wire is always 12 volts and the other wire is connected to earth when horn button pressed.
check fire wall of car some kia have horn on firewall in engine compartment. or it is under the grill in front of car.
Sep 07, 2012 | 2005 Kia Carens
I have a kia carens 2001, making a knocking on right side when accelerating and turning left and a lil on the right and steering is jumping when accelerating and at 70km pls help
common fault on kia carens is the drive shafts ive had to replace both mine its a easy job to do but will set you back about 130 pound a side.
Jun 04, 2012 | 2005 Kia Carens
Kia carens 2003. (UK) Don't know alternate name.
Aug 13, 2010 | 2005 Kia Rondo
How to fit a wheel bearing to a kia carens front wheel.kia carens is not in the drop dowm menu
Aug 10, 2010 | 2002 Kia Sedona
How do I get to the heater filter on my 2009 kia carens . I am presuming the pollen filter is behind the glove box, but I cant see any screws to get the glove box assembly out or in fact where the filter...
I eventually found the answer to my problem on a website called kia-forums.com telling me to open the glove box and pull it sharply and backwards.it disconnects from the plastic hinges. The filters are easy to replace by unclipping the cover which is easy to see. This is for a 2004 kia carens
Dec 30, 2009 | 2007 Kia Sedona LX Minivan
Not holding on slopes
May 10, 2009 | Kia Optima Cars & Trucks
Car Audio & Video Logo
420 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
